跳转到主内容
加入维修社区 - 创建账户
Bose SoundTouch 20 Motherboard Replacement
你所需要的
    1. Bose SoundTouch 20 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Bose SoundTouch 20 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
      • Remove the (6) six 1.5mm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
      • Lift the cover straight up and set the cover aside.
      添加评论
    2. Bose SoundTouch 20 Motherboard Replacement: 步骤 2 中的图像 1,2 Bose SoundTouch 20 Motherboard Replacement: 步骤 2 中的图像 2,2
      • Gently pull the white ribbon from the connector on the top side of the power board.
      • Make sure to pull straight back so you don't bend or damage the ribbon.
      询问修复机器人
      添加评论
    3. Bose SoundTouch 20 Motherboard Replacement: 步骤 3 中的图像 1,2 Bose SoundTouch 20 Motherboard Replacement: 步骤 3 中的图像 2,2
      • Remove the (4) four 1.5 cm screws connecting the power board to the speaker.
      • Remove the (2) two 1 cm screws connecting the power board to the speaker.
      • Gently lift the board up.
      • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
      询问修复机器人
      添加评论
    4. Bose SoundTouch 20 Motherboard Replacement: 步骤 4 中的图像 1,2 Bose SoundTouch 20 Motherboard Replacement: 步骤 4 中的图像 2,2
      • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
      询问修复机器人
      添加评论
    5. Bose SoundTouch 20 Motherboard Replacement: 步骤 5 中的图像 1,2 Bose SoundTouch 20 Motherboard Replacement: 步骤 5 中的图像 2,2
      • Gently pull the thinner white ribbon towards the center of the board.
      • Pull straight down to prevent bending or damaging the ribbon.
      • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
      • Remove the motherboard.
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
USF Tampa, Team S11-G3, Passmore Fall 2017 USF Tampa, Team S11-G3, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G3
4 名成员
创作了21篇指南
8指南评论
But how do I purchase a new motherboard?
Donald Weber - 回复 分享
Thank you for excellent information and instruction. Can you please send some link to order a new motherboard?
leo.benjamin - 回复 分享
Thank you for the tutorial. How do I purchase a new motherboard ?
benjamin lozano - 回复 分享
Any known place to purchase a replacement board?
Marceli Palak - 回复 分享
Any luck with a place to purchase a replcement board ?
Henry - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 119
总计 10,533
