跳转到主内容
加入维修社区 - 创建账户
Bose SoundTouch 20 Amplifier Replacement
你所需要的
    1. Bose SoundTouch 20 Amplifier Replacement, Amplifier: 步骤 1 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement, Amplifier: 步骤 1 中的图像 2,2
      • Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
      • Lift the cover straight up and set the cover to the side.
      询问修复机器人
      添加评论
    2. Bose SoundTouch 20 Amplifier Replacement: 步骤 2 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement: 步骤 2 中的图像 2,2
      • Gently pull the white ribbon from the connector on the top side of the motherboard.
      • Make sure to pull straight back so you don't bend or damage the ribbon.
      询问修复机器人
      添加评论
    3. Bose SoundTouch 20 Amplifier Replacement: 步骤 3 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement: 步骤 3 中的图像 2,2
      • Remove the (4) four 1.5 cm screws connecting the motherboard to the speaker.
      • Remove the (2) two 1 cm screws connecting the motherboard to the speaker.
      • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
      询问修复机器人
      添加评论
    4. Bose SoundTouch 20 Amplifier Replacement: 步骤 4 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement: 步骤 4 中的图像 2,2
      • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
      询问修复机器人
      添加评论
    5. Bose SoundTouch 20 Amplifier Replacement: 步骤 5 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement: 步骤 5 中的图像 2,2
      • Gently pull the thinner white ribbon located towards the center of the board
      • Pull straight down to prevent bending or damaging the ribbon.
      • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
      • After removing the two ribbons, completely remove the motherboard and set it to the side.
      询问修复机器人
      添加评论
    6. Bose SoundTouch 20 Amplifier Replacement: 步骤 6 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement: 步骤 6 中的图像 2,2
      • To remove the side panel from the speaker, lift the top of the sides from the slots.
      • The sides will be bent up after removing from the slots, they do not come up right away.
      • After completing the previous step, pull gently straight up to remove the side.
      • Repeat on both sides of the speaker.
      询问修复机器人
      添加评论
    7. Bose SoundTouch 20 Amplifier Replacement: 步骤 7 中的图像 1,3 Bose SoundTouch 20 Amplifier Replacement: 步骤 7 中的图像 2,3 Bose SoundTouch 20 Amplifier Replacement: 步骤 7 中的图像 3,3
      • Remove the (2) two 1.5 cm screws circled in picture one.
      • Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
      询问修复机器人
      添加评论
    8. Bose SoundTouch 20 Amplifier Replacement: 步骤 8 中的图像 1,2 Bose SoundTouch 20 Amplifier Replacement: 步骤 8 中的图像 2,2
      • After lifting the cover, you will see two ribbons attaching the cover to the speaker. Gently remove these ribbons by pulling straight down.
      • Make sure to pull the ribbons straight out so you don't bend or damage the ribbon.
      询问修复机器人
      添加评论
    9. Bose SoundTouch 20 Amplifier Replacement: 步骤 9 中的图像 1,1
      • Remove the (14) fourteen 1 cm screws from the speaker.
      • Remove the (2) two 1.5 cm screws from the top left and right hand corners of the speakers, respectively.
      询问修复机器人
      添加评论
    10. Bose SoundTouch 20 Amplifier Replacement: 步骤 10 中的图像 1,3 Bose SoundTouch 20 Amplifier Replacement: 步骤 10 中的图像 2,3 Bose SoundTouch 20 Amplifier Replacement: 步骤 10 中的图像 3,3
      • Using a metal spudger or a prying tool, gently push forward to separate the cover from the speaker.
      询问修复机器人
      添加评论
    11. Bose SoundTouch 20 Amplifier Replacement: 步骤 11 中的图像 1,1
      • Gently pull out the speaker from the placeholder by twisting and turning it.
      • The speaker is heavy and very magnetic.
      询问修复机器人
      添加评论
    12. Bose SoundTouch 20 Amplifier Replacement: 步骤 12 中的图像 1,1
      • The amplifier comes as one piece. Once the speakers are removed, the part is ready to be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
团队
USF Tampa, Team S11-G3, Passmore Fall 2017 USF Tampa, Team S11-G3, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G3
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 80
总计 6,780
