跳转到主内容
加入维修社区 - 创建账户
Bose SoundLink Mini Button Switch Circuit Board Replacement
你所需要的
    1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery: 步骤 1 中的图像 1,1
      • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
      添加评论
    2. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 2 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 2 中的图像 2,2
      • While holding the cover back, pull straight up on the battery to remove it.
      添加评论
    1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Front/Back Protective Grille: 步骤 3 中的图像 1,1
      • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
      • Place Metal Spudger in the location shown.
      添加评论
    2. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 4 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 4 中的图像 2,2
      • Slowly pry up the grille until the two tabs shown pop out.
      • Be very gentle, the grille will bend.
      询问修复机器人
      添加评论
    3. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 5 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 5 中的图像 2,2
      • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
      询问修复机器人
      添加评论
    4. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 6 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 6 中的图像 2,2
      • Repeat steps to remove the back grille.
      添加评论
    1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: 步骤 7 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: 步骤 7 中的图像 2,2
      • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
      添加评论
    2. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 8 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 8 中的图像 2,2
      • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
      询问修复机器人
      添加评论
    3. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 9 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 9 中的图像 2,2
      • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
      添加评论
    1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Button Switch Circuit Board: 步骤 10 中的图像 1,1
      • Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
      • The black tab must be flipped up in order to reinsert the ribbon cable on reassembly.
      添加评论
    2. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 11 中的图像 1,3 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 11 中的图像 2,3 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 11 中的图像 3,3
      • Use a Metal Spudger to pry up the plastic divider.
      询问修复机器人
      添加评论
    3. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 12 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 12 中的图像 2,2
      • When removing the plastic divider be careful not to damage the wire strip sliding through it.
      询问修复机器人
      添加评论
    4. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 13 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 13 中的图像 2,2
      • Reach through the battery compartment hole and unplug the power strip shown.
      添加评论
    5. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 14 中的图像 1,3 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 14 中的图像 2,3 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 14 中的图像 3,3
      • Remove both circuit boards by wiggling them up and out of the casing.
      • Unplug the speaker wires connected and fully remove both circuit boards.
      • When unplugging the speaker wires, squeeze the white connector piece to release the wires.
      询问修复机器人
      添加评论
    6. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 15 中的图像 1,2 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 15 中的图像 2,2
      • Unhook the speaker wires clipped onto the button switch circuit board.
      询问修复机器人
      添加评论
    7. Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 16 中的图像 1,3 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 16 中的图像 2,3 Bose SoundLink Mini Button Switch Circuit Board Replacement: 步骤 16 中的图像 3,3
      • Use a nylon or metal spudger to slightly lift up on the button switch circuit board.
      • Pull the button switch circuit board straight out from the casing.
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
团队
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 的会员
CPSU-MANESS-F15S1G23
4 名成员
创作了34篇指南
12指南评论
Hello
Where I can buy circuit
candellaaria - 回复 分享
Yes were can we get the replacement part? ?
sonny goddin - 回复 分享
Hi sonny,
did you find this part ? (the first circuit board)
luc.lacouture - 回复 分享
Hi
Can you get the relacement part for the mini II or is it the same - and if
- where and how to order for delivery to Europe?
Andreas Burckhart - 回复 分享
Kindly can you tell me is th bose Soundlink mini first generation has an update or not, because it started no charge and the ember ligy keep flashing and some times reed color , I bought a new battery but still the same now it’s playing up
Moqdam Aljwrany - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 77
过去 30 天: 339
总计 41,027
