跳转到主内容
加入维修社区 - 创建账户
Bose SoundDock Portable v2 Remote Battery Replacement
你所需要的
    1. Bose SoundDock Portable v2 Remote Battery Replacement, Remote Battery: 步骤 1 中的图像 1,1
      • Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
      询问修复机器人
      添加评论
    2. Bose SoundDock Portable v2 Remote Battery Replacement: 步骤 2 中的图像 1,2 Bose SoundDock Portable v2 Remote Battery Replacement: 步骤 2 中的图像 2,2
      • Remove cover and battery. The new battery should be placed with the positive (flat) side facing up.
      • The correct battery for your remote is a CR2032. You may also use a DL2032.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G1
4 名成员
创作了15篇指南
1指南评论
We have a Bose Wave radio w/remote. This remote is not the one shown here with a screw for the battery compartment. It's the type w/a sliding holder for the battery on the south end (bottom of the battery). Someone went to replace the battery and shoved the holder in upside down I believe. Consequently the holder will not come out all the way.
There must be a way to get it out without forcing it. There's a pinch clip you have to either squeeze or move to the left to disengage it from the locked position and free it up. Any ideas as to how to accomplish this? We appreciate a reply back so this would make our Christmas better.
Merry Christmas & Happy Holidays! Cheers!
asbirdiesingh - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 160
总计 16,070
