跳转到主内容
加入维修社区 - 创建账户
Bose SoundDock Portable v2 Docking System Board Replacement
你所需要的
    1. Bose SoundDock Portable v2 Docking System Board Replacement, Docking System Board: 步骤 1 中的图像 1,1
      • Lay the speaker flat on its back, balancing on the battery.
      • Remove the four rubber disks that cover the screws on the bottom of the speaker.
      • Follow the battery replacement guide to remove the battery
      询问修复机器人
      添加评论
    2. Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 2 中的图像 1,1
      • Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
      • It may be easier to the remove the battery so that the speaker will lay flat on the table.
      询问修复机器人
      添加评论
    3. Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 3 中的图像 1,1
      • Carefully remove the bottom panel of the speaker.
      • You may have to rock the panel back and forth to get it to slide off the plastic pegs.
      询问修复机器人
      添加评论
    4. Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 4 中的图像 1,1
      • Once the panel is removed you will see a ribbon connecting the dock to the speaker. Be careful to orient the speaker so that you can work on the dock connector without pulling on the ribbon!
      询问修复机器人
      添加评论
    5. Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 5 中的图像 1,2 Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 5 中的图像 2,2
      • Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
      • There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
      询问修复机器人
      添加评论
    6. Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 6 中的图像 1,2 Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 6 中的图像 2,2
      • Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
      • There are some small parts that may fall out when the plastic pieces are separated. To minimize this, lay the piece with the dock connector facing down.
      询问修复机器人
      添加评论
    7. Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 7 中的图像 1,2 Bose SoundDock Portable v2 Docking System Board Replacement: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Once the pieces are separated, the dock connector can be lifted out of the slot.
      • Using tweezers or your fingers, unplug the two ribbon connectors from the board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Evan Low
于04/14/15注册
584 声望
创作了4篇指南
团队
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G1
4 名成员
创作了40篇指南
2指南评论
How can I tell if it is my IPOD or the Bose system that needs to be repaired?
Ron Adams - 回复 分享
Where can I by this piece? I have to replace that piece.
PHelmut - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 109
总计 23,269
