跳转到主内容
Bose Quiet Comfort 35 II Speaker Driver Replacement
你所需要的
  1. Bose Quiet Comfort 35 II Speaker Driver Replacement, Speaker Driver: 步骤 1 中的图像 1,1
    • Take off the ear cushion pad using the plastic opening tool on the right headphone.
    • This will be done using a prying motion between the cushion pad and the headphone itself.
  2. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 2 中的图像 1,2 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 2 中的图像 2,2
    • Take off the ear cover off by peeling the glue back with hands.
  3. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 3 中的图像 1,1
    • Remove the two 7-millimeter silver screws on the right earphone using the Phillips #000 to disconnect the back cover.
  4. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 4 中的图像 1,1
    • Remove the two 5-millimeter silver screws attaching the earphone to the headband using the Phillips #000.
  5. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 5 中的图像 1,2 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 5 中的图像 2,2
    • Detach the earpiece from the band to reach the speaker driver with better access.
    • This will be done with your hands. The connecting piece can slide out and allow it to detach.
  6. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 6 中的图像 1,1
    • Detach the silver cover piece on the outside of the headset using the black stick spudger.
    • This will be done by entering the black stick spudger in an opening and pry the cover piece off.
  7. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 7 中的图像 1,2 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 7 中的图像 2,2
    • Remove the four 5-millimeter black screws using the Phillips #000 around the circuit board.
  8. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 8 中的图像 1,1
    • Take off the gray on/off switch on the circuit board.
    • This can be done with your fingers. Just pull up on the switch and it should detach.
  9. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 9 中的图像 1,2 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 9 中的图像 2,2
    • Pry off the glued ribbon cables with the black stick spudger by entering it below the ribbon cable and pulling it up.
    • This prying motion will allow the ribbon cable to come off safely.
  10. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 10 中的图像 1,3 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 10 中的图像 2,3 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 10 中的图像 3,3
    • Detach the second ribbon wire for the charging cable with your hands by pulling each side of the component to separate it.
    • No extra tools are needed.
  11. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 11 中的图像 1,1
    • Use the iOpener to loosen the glue on the speaker cover by laying it on top of the glue.
  12. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 12 中的图像 1,1
    • Pry off the speaker cover using the flathead from the Plastic Spudger Set.
    • Enter the flathead under the plastic speaker cover and pry in an upwards motion.
  13. Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 13 中的图像 1,2 Bose Quiet Comfort 35 II Speaker Driver Replacement: 步骤 13 中的图像 2,2
    • De-solder the two speaker wires off of their post.
    • Prior knowledge is needed for this step, it can be very hazardous.
    • You can now reach the speaker driver and replace it with a new part.
结论
kssexton
于11/08/23注册
463 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Harley Fall 2023 IUPUI, Team 1-2, Harley Fall 2023 的会员
IUPUI-HARLEY-F23S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 36
过去 30 天: 157
总计 796
