跳转到主内容
加入维修社区 - 创建账户
Bosch PS21 Motor Replacement
你所需要的
    1. Bosch PS21 Motor Replacement, Battery: 步骤 1 中的图像 1,1
      • Pinch the two release tabs on the sides of the battery, and slide the battery out.
      添加评论
    1. Bosch PS21 Motor Replacement, Motor: 步骤 2 中的图像 1,2 Bosch PS21 Motor Replacement, Motor: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      $3.99
      • After removing the battery pack, locate the clip that connects the two halves of the outer casing shown in the picture. Remove the clip using angled tweezers or a similar tool. Save the clip for reassembly.
      询问修复机器人
      添加评论
    2. Bosch PS21 Motor Replacement: 步骤 3 中的图像 1,1
      • Locate the eight 5.5 mm screws as shown in the picture.
      • Remove each screw using a small Phillips head screw driver. Save all the screws for reassembly.
      询问修复机器人
      添加评论
    3. Bosch PS21 Motor Replacement: 步骤 4 中的图像 1,2 Bosch PS21 Motor Replacement: 步骤 4 中的图像 2,2
      • Starting at the rear of the drill, use a wedge to separate the two halves of the outer case at the parting line.
      询问修复机器人
      添加评论
    4. Bosch PS21 Motor Replacement: 步骤 5 中的图像 1,2 Bosch PS21 Motor Replacement: 步骤 5 中的图像 2,2
      • The motor and trigger assembly are connected by two wires. Do not pull or put tension on these wires.
      • Lift up the metal tab as shown in the first picture to free the trigger assembly.
      • Gently dislodge the motor and trigger assembly from the drill case. Remove the components as one piece, shown in the second picture.
      询问修复机器人
      添加评论
    5. Bosch PS21 Motor Replacement: 步骤 6 中的图像 1,3 Bosch PS21 Motor Replacement: 步骤 6 中的图像 2,3 Bosch PS21 Motor Replacement: 步骤 6 中的图像 3,3
      • Be sure to not grip the pliers too firmly, as it could cause damage to the wire connectors.
      • Firmly secure the motor assembly in place. Using a set of pliers, carefully pull the black wire connector away from the motor. Repeat this action with the red wire connector.
      • The wire connections on the motor are color coded, matching the color wire that connects there.
      询问修复机器人
      添加评论
    6. Bosch PS21 Motor Replacement: 步骤 7 中的图像 1,3 Bosch PS21 Motor Replacement: 步骤 7 中的图像 2,3 Bosch PS21 Motor Replacement: 步骤 7 中的图像 3,3
      • Once the wires have been disconnected, separate the trigger mechanism from the motor assembly.
      • Place your hands on each end of mechanism and carefully pull apart the assembly in order to separate the gearbox from the motor.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
IUPUI, Team 1-2, Harley Spring 2016 IUPUI, Team 1-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S1G2
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 41
总计 3,842
