简介
This guide shows the process of replacing a broken boot zipper.
Broken zippers are a common issue found on daily clothing, especially boots. Over time, zippers can wear out due to regular use. The teeth may become worn, or the slider may lose its grip, leading to malfunction. Sometimes, forcing the zipper when it’s stuck or overloading the boot can also cause the zipper to break, for zippers are designed to handle a certain amount of stress, and exceeding this can lead to damage. Broken zippers lead to the boots seen as unusable and open up the possibility for it to be thrown away.
Therefore, addressing these issues promptly can help extend the life of your boots and prevent the need for more extensive repairs or replacements.
With this guide, we will show how to replace a boot zipper, saving the overall boot and lessening the waste of thrown-out clothing.
你所需要的
Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
