跳转到主内容
加入维修社区 - 创建账户
Boosted Board 1st Generation Belts Replacement
你所需要的
    1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: 步骤 1 中的图像 1,2 Boosted Board 1st Generation Belts Replacement, Rear Wheels: 步骤 1 中的图像 2,2
      • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
      • Do Not Remove the Screws.
      询问修复机器人
      添加评论
    2. Boosted Board 1st Generation Belts Replacement: 步骤 2 中的图像 1,1
      • Compress the motor mount back towards the wheel.
      • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
      • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
      询问修复机器人
      添加评论
    3. Boosted Board 1st Generation Belts Replacement: 步骤 3 中的图像 1,2 Boosted Board 1st Generation Belts Replacement: 步骤 3 中的图像 2,2
      • Remove the axel nut with a 1/2" socket wrench
      询问修复机器人
      添加评论
    4. Boosted Board 1st Generation Belts Replacement: 步骤 4 中的图像 1,3 Boosted Board 1st Generation Belts Replacement: 步骤 4 中的图像 2,3 Boosted Board 1st Generation Belts Replacement: 步骤 4 中的图像 3,3
      • Rotate and pull counterclockwise until the wheel comes off the axle completely.
      • The front washer will come off with the wheel.
      • Remove the back washer from the axle.
      • Replacing the wheel requires the bearings to be switched into the new wheel.
      询问修复机器人
      添加评论
    1. Boosted Board 1st Generation Belts Replacement, Belts: 步骤 5 中的图像 1,3 Boosted Board 1st Generation Belts Replacement, Belts: 步骤 5 中的图像 2,3 Boosted Board 1st Generation Belts Replacement, Belts: 步骤 5 中的图像 3,3
      • Compress the motor mount back .
      • Slide the belt off the axle
      询问修复机器人
      添加评论
    2. Boosted Board 1st Generation Belts Replacement: 步骤 6 中的图像 1,1
      • Remove the two hex screws.
      • Remove the front hex screw.
      • When removing the Front hex screw, hold the motor mount and the truck together.
      • The springs inside the motor mount will push the motor out of the casing if they are not held together.
      询问修复机器人
      添加评论
    3. Boosted Board 1st Generation Belts Replacement: 步骤 7 中的图像 1,3 Boosted Board 1st Generation Belts Replacement: 步骤 7 中的图像 2,3 Boosted Board 1st Generation Belts Replacement: 步骤 7 中的图像 3,3
      • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
      • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Emily Imfeld
于10/06/16注册
532 声望
创作了4篇指南
团队
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G7
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 2,065
