跳转到主内容
加入维修社区 - 创建账户
Boogie Board Rip Copper Button Plate Replacement
你所需要的
  1. Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: 步骤 1 中的图像 1,2 Boogie Board Rip Copper Button Plate Replacement, Accessing the internal components: 步骤 1 中的图像 2,2
    • On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
    • A Torx bit is the piece that is inserted into a bit driver, also known as a screw driver.
    询问修复机器人
    添加评论
  2. Boogie Board Rip Copper Button Plate Replacement: 步骤 2 中的图像 1,3 Boogie Board Rip Copper Button Plate Replacement: 步骤 2 中的图像 2,3 Boogie Board Rip Copper Button Plate Replacement: 步骤 2 中的图像 3,3
    • Remove the stylus if it is in the housing at the top of the device.
    • Turn the device so you are looking at it from the top down.
    • Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
    询问修复机器人
    添加评论
  3. Boogie Board Rip Copper Button Plate Replacement: 步骤 3 中的图像 1,3 Boogie Board Rip Copper Button Plate Replacement: 步骤 3 中的图像 2,3 Boogie Board Rip Copper Button Plate Replacement: 步骤 3 中的图像 3,3
    • Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device.
    • Remove the front face plate by pulling it straight up.
    • The unlock switch on the device's side might come off while undoing the internal snaps or removing the face plate. This is perfectly normal.
    询问修复机器人
    添加评论
  4. Boogie Board Rip Copper Button Plate Replacement: 步骤 4 中的图像 1,2 Boogie Board Rip Copper Button Plate Replacement: 步骤 4 中的图像 2,2
    • Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
    询问修复机器人
    添加评论
  5. Boogie Board Rip Copper Button Plate Replacement: 步骤 5 中的图像 1,2 Boogie Board Rip Copper Button Plate Replacement: 步骤 5 中的图像 2,2
    • With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
    询问修复机器人
    添加评论
  6. Boogie Board Rip Copper Button Plate Replacement: 步骤 6 中的图像 1,2 Boogie Board Rip Copper Button Plate Replacement: 步骤 6 中的图像 2,2
    • Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard.
    • Remove the battery hidden behind the motherboard.
    添加评论
  7. Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: 步骤 7 中的图像 1,2 Boogie Board Rip Copper Button Plate Replacement, Copper Button Plate: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers gently go around the edges of the copper plate to remove the adhesive.
    询问修复机器人
    添加评论
  8. Boogie Board Rip Copper Button Plate Replacement: 步骤 8 中的图像 1,2 Boogie Board Rip Copper Button Plate Replacement: 步骤 8 中的图像 2,2
    • Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Gareth
于09/09/14注册
360 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-6, Bruce Fall 2014 CSU Fullerton, Team 2-6, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G6
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 32
总计 2,991
