跳转到主内容
BolaButty X-GO C27-C Battery Replacement
你所需要的
  1. BolaButty X-GO C27-C Battery Replacement, Charging Port: 步骤 1 中的图像 1,3 BolaButty X-GO C27-C Battery Replacement, Charging Port: 步骤 1 中的图像 2,3 BolaButty X-GO C27-C Battery Replacement, Charging Port: 步骤 1 中的图像 3,3
    • Take an opening tool or pick and wedge it into the groove between the endcap and the main casing. Wiggle it back and forth.
    • Strike the speaker endcap firmly against a solid surface to pop the end caps off.
    • Removing the end caps requires a good amount of force. There is a realistic chance that you will damage your speaker or break the caps.
  2. BolaButty X-GO C27-C Battery Replacement: 步骤 2 中的图像 1,2 BolaButty X-GO C27-C Battery Replacement: 步骤 2 中的图像 2,2
    • Wedge an opening tool or a pick under the speaker cover and work it back and forth to loosen it. Repeat for all four sides.
    • Remove the speaker cover.
  3. BolaButty X-GO C27-C Battery Replacement: 步骤 3 中的图像 1,2 BolaButty X-GO C27-C Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the eight 12 mm screws securing the driver housing using a Phillips #0 screwdriver.
    • Gently pull apart the two halves of the speaker.
    • Take care not to strain the cables.
  4. BolaButty X-GO C27-C Battery Replacement: 步骤 4 中的图像 1,2 BolaButty X-GO C27-C Battery Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the three 10 mm screws securing the charging housing.
    • Separate the charging port from the battery.
  5. BolaButty X-GO C27-C Battery Replacement: 步骤 5 中的图像 1,2 BolaButty X-GO C27-C Battery Replacement: 步骤 5 中的图像 2,2
    • Use a pair of tweezers to lift the black ZIF locking flap securing the ribbon attached to the charging port.
    • While pulling up on the latch, remove the ribbon.
  6. BolaButty X-GO C27-C Battery Replacement, Battery: 步骤 6 中的图像 1,2 BolaButty X-GO C27-C Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Disconnect the battery connector from its motherboard port.
  7. BolaButty X-GO C27-C Battery Replacement: 步骤 7 中的图像 1,2 BolaButty X-GO C27-C Battery Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to lift the battery from the casing.
    • The battery is secured with some adhesive. If you have a difficult time removing it, use a hairdryer to lightly heat the adhesive.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
另外一个人完成了本指南。
jcate
于03/21/25注册
497 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-5, Botvin Spring 2025 UMass Dartmouth, Team 3-5, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S3G5
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 60
总计 461
