跳转到主内容
加入维修社区 - 创建账户
Body Panel Removal
你所需要的
  1. Body Panel Removal, Remove film door: 步骤 1 中的图像 1,1
    • Push down the latch to release the film door.
    询问修复机器人
    添加评论
  2. Body Panel Removal, Remove top cover screws: 步骤 2 中的图像 1,3 Body Panel Removal, Remove top cover screws: 步骤 2 中的图像 2,3 Body Panel Removal, Remove top cover screws: 步骤 2 中的图像 3,3
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
    询问修复机器人
    添加评论
  3. Body Panel Removal, Remove top cover screws: 步骤 3 中的图像 1,3 Body Panel Removal, Remove top cover screws: 步骤 3 中的图像 2,3 Body Panel Removal, Remove top cover screws: 步骤 3 中的图像 3,3
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
    询问修复机器人
    添加评论
  4. Body Panel Removal, Lift top cover: 步骤 4 中的图像 1,1
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
    询问修复机器人
    添加评论
  5. Body Panel Removal, Access flash connections: 步骤 5 中的图像 1,2 Body Panel Removal, Access flash connections: 步骤 5 中的图像 2,2
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
    询问修复机器人
    添加评论
  6. Body Panel Removal, Discharge flash capacitors: 步骤 6 中的图像 1,1
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    询问修复机器人
    添加评论
  7. Body Panel Removal, Disconnect right flex cable: 步骤 7 中的图像 1,1
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    询问修复机器人
    添加评论
  8. Body Panel Removal, Disconnect left flex cable: 步骤 8 中的图像 1,1
    • Desolder the red wire.
    询问修复机器人
    添加评论
  9. Body Panel Removal, Desolder flash connections: 步骤 9 中的图像 1,2 Body Panel Removal, Desolder flash connections: 步骤 9 中的图像 2,2
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
    询问修复机器人
    添加评论
  10. Body Panel Removal, Desolder the flash flex cable: 步骤 10 中的图像 1,2 Body Panel Removal, Desolder the flash flex cable: 步骤 10 中的图像 2,2
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
    询问修复机器人
    添加评论
  11. Body Panel Removal, Remove bottom cover: 步骤 11 中的图像 1,3 Body Panel Removal, Remove bottom cover: 步骤 11 中的图像 2,3 Body Panel Removal, Remove bottom cover: 步骤 11 中的图像 3,3
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
    • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    询问修复机器人
    添加评论
  12. Body Panel Removal, Remove front left cover: 步骤 12 中的图像 1,1
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
    询问修复机器人
    添加评论
  13. Body Panel Removal, Remove front cover: 步骤 13 中的图像 1,1
    • Remove front cover.
    询问修复机器人
    添加评论
  14. Body Panel Removal, Unscrew front right cover: 步骤 14 中的图像 1,3 Body Panel Removal, Unscrew front right cover: 步骤 14 中的图像 2,3 Body Panel Removal, Unscrew front right cover: 步骤 14 中的图像 3,3
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
    询问修复机器人
    添加评论
  15. Body Panel Removal, Remove the front right cover: 步骤 15 中的图像 1,1
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Sam Gustafson
于09/01/22注册
11,000 声望
创作了78篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 44
总计 588
