跳转到主内容
加入维修社区 - 创建账户
Blu Dash 5.0 Dual SIM Display Cable Replacement
你所需要的
  1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
    添加评论
  2. Blu Dash 5.0 Dual SIM Display Cable Replacement: 步骤 2 中的图像 1,1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
    询问修复机器人
    添加评论
  3. Blu Dash 5.0 Dual SIM Display Cable Replacement, Display Cable: 步骤 3 中的图像 1,1
    • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
    • The screw holes with the red circle around them hold screws with a 3.5 mm length.
    • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
    询问修复机器人
    添加评论
  4. Blu Dash 5.0 Dual SIM Display Cable Replacement: 步骤 4 中的图像 1,2 Blu Dash 5.0 Dual SIM Display Cable Replacement: 步骤 4 中的图像 2,2
    • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
    • Do this for each corner until the panel pops up.
    询问修复机器人
    添加评论
  5. Blu Dash 5.0 Dual SIM Display Cable Replacement: 步骤 5 中的图像 1,3 Blu Dash 5.0 Dual SIM Display Cable Replacement: 步骤 5 中的图像 2,3 Blu Dash 5.0 Dual SIM Display Cable Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
    • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
团队
UMass Dartmouth, Team 4-7, Miles Fall 2014 UMass Dartmouth, Team 4-7, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G7
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 29
总计 3,395
