跳转到主内容
加入维修社区 - 创建账户
Blackberry Torch 9810 Cursor Key Replacement
你所需要的
    1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: 步骤 1 中的图像 1,2 Blackberry Torch 9810 Cursor Key Replacement, Phone cover: 步骤 1 中的图像 2,2
      • Remove the back cover of the phone
      询问修复机器人
      添加评论
    2. Blackberry Torch 9810 Cursor Key Replacement, Battery: 步骤 2 中的图像 1,1
      • Remove the battery
      询问修复机器人
      添加评论
    3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: 步骤 3 中的图像 1,1
      • Unscrew the four screws using the T6 screw driver.
      • If you remove the screw in red, you void the warranty!
      询问修复机器人
      添加评论
    4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: 步骤 4 中的图像 1,2 Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: 步骤 4 中的图像 2,2
      • Slide the screen up.
      • Remove front silver trim by using a plastic opening tools and wiggle it off.
      • This is difficult to remove, but it should come off if you do it with caution.
      询问修复机器人
      添加评论
    5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: 步骤 5 中的图像 1,1
      • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
      询问修复机器人
      添加评论
    6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 步骤 6 中的图像 1,3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 步骤 6 中的图像 2,3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 步骤 6 中的图像 3,3
      • Use the plastic opening tools to remove the entire back off the phone.
      询问修复机器人
      添加评论
    7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: 步骤 7 中的图像 1,1
      • Remove the three ribbon cables and the antenna wire by hand.
      • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
      询问修复机器人
      添加评论
    8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: 步骤 8 中的图像 1,1
      • The logic board will easily pull straight out.
      询问修复机器人
      添加评论
    9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: 步骤 9 中的图像 1,1
      • Remove the black sticker located above the logic board that contains the phone's serial number
      询问修复机器人
      添加评论
    10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: 步骤 10 中的图像 1,1
      • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
      询问修复机器人
      添加评论
    11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: 步骤 11 中的图像 1,1
      • Carefully separate the screen from the body.
      • Make sure to be extra careful with the ribbon!
      询问修复机器人
      添加评论
    12. Blackberry Torch 9810 Cursor Key Replacement: 步骤 12 中的图像 1,1
      • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
      • They are on a black cover located on the bottom of the phone. The black cover will come off
      询问修复机器人
      添加评论
    13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: 步骤 13 中的图像 1,1
      • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
      询问修复机器人
      添加评论
    14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 步骤 14 中的图像 1,3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 步骤 14 中的图像 2,3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 步骤 14 中的图像 3,3
      • Push the cursor upwards and out of the socket.
      • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G6
3 名成员
创作了40篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 1,814
