跳转到主内容
加入维修社区 - 创建账户
Blackberry 8110 Camera Replacement
你所需要的
  1. Blackberry 8110 Camera Replacement, Removing the back cover.: 步骤 1 中的图像 1,2 Blackberry 8110 Camera Replacement, Removing the back cover.: 步骤 1 中的图像 2,2
    • Turn the phone over so that the screen is facing the table. Locate the chrome release button and push it in to unclip the battery cover.
    询问修复机器人
    添加评论
  2. Blackberry 8110 Camera Replacement, Removing the screws.: 步骤 2 中的图像 1,2 Blackberry 8110 Camera Replacement, Removing the screws.: 步骤 2 中的图像 2,2
    • Now that the battery cover has been removed, locate the two 7.5mm Torx #T6 screws at the top of the phone. Remove these by turning counter-clockwise with your T6 screwdriver.
    询问修复机器人
    添加评论
  3. Blackberry 8110 Camera Replacement, Removing the bottom cover.: 步骤 3 中的图像 1,2 Blackberry 8110 Camera Replacement, Removing the bottom cover.: 步骤 3 中的图像 2,2
    • Now that the two screws at the top have been removed, take your spudger and locate the two gaps to the left and right of the button that releases the battery cover.
    • With your spudger, carefully wedge it into the gap and pry downwards to release the bottom cover.
    询问修复机器人
    添加评论
  4. Blackberry 8110 Camera Replacement, Removng the screws from the front side.: 步骤 4 中的图像 1,2 Blackberry 8110 Camera Replacement, Removng the screws from the front side.: 步骤 4 中的图像 2,2
    • Turn the phone over so that the screen is facing up. With the bottom cover off, you will be able to locate two 7.5mm Torx #T6 screws in each corner below the keyboard. Carefully remove these.
    询问修复机器人
    添加评论
  5. Blackberry 8110 Camera Replacement, Taking off the side panels.: 步骤 5 中的图像 1,3 Blackberry 8110 Camera Replacement, Taking off the side panels.: 步骤 5 中的图像 2,3 Blackberry 8110 Camera Replacement, Taking off the side panels.: 步骤 5 中的图像 3,3
    • Now that the screws on the front have been removed, take your spudger and wedge it between the trim on the side of the phone, and the phone itself. Carefully pry the trim away from the phone.
    询问修复机器人
    添加评论
  6. Blackberry 8110 Camera Replacement, Removing the back panel.: 步骤 6 中的图像 1,2 Blackberry 8110 Camera Replacement, Removing the back panel.: 步骤 6 中的图像 2,2
    • You are now ready to remove the back panel. In order to do this, locate the two clips on each side of the phone (underneath the trim that you just removed).
    • Once you locate these clips (four in total, two on each side), you should be able to unclip them with your fingers.
    • Be gentle as to not break the clips in doing so.
    询问修复机器人
    添加评论
  7. Blackberry 8110 Camera Replacement, Removing the front panel.: 步骤 7 中的图像 1,2 Blackberry 8110 Camera Replacement, Removing the front panel.: 步骤 7 中的图像 2,2
    • The front panel is now ready to be removed from the rest of the phone. To do this, just pry the front part (with the keyboard and screen) away from the logic board of the phone with your fingers.
    询问修复机器人
    添加评论
  8. Blackberry 8110 Camera Replacement, Remove the camera: 步骤 8 中的图像 1,3 Blackberry 8110 Camera Replacement, Remove the camera: 步骤 8 中的图像 2,3 Blackberry 8110 Camera Replacement, Remove the camera: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • With the back of the logic board facing up (display side of logic board facing down) camera is located on the top-left side. The camera is held down by metal clips along the sides.
    • Use the tweezers to hold the housing of the camera piece and rock the camera forward (bending the metal clips outward).
    • While still holding the camera with the tweezers rock in the opposite direction to bend the metal clips outward on the opposite side and freeing the camera piece for replacement.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Nazimbe
于09/25/14注册
95 声望
撰写一个指南
团队
USF Tampa, Team 1-2, Brown Fall 2014 USF Tampa, Team 1-2, Brown Fall 2014 的会员
USFT-BROWN-F14S1G2
3 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 646
