跳转到主内容
加入维修社区 - 创建账户
BlackBerry Curve 8530 Keypad Replacement
你所需要的
  1. BlackBerry Curve 8530 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the phone on a flat surface with the screen facing down.
    • Remove the plastic backplate by pulling up on the bottom of the cover.
    询问修复机器人
    添加评论
  2. BlackBerry Curve 8530 Keypad Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up from the top of the battery.
    询问修复机器人
    添加评论
  3. BlackBerry Curve 8530 Keypad Replacement, Keypad: 步骤 3 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement, Keypad: 步骤 3 中的图像 2,2
    • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
    • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
    询问修复机器人
    添加评论
  4. BlackBerry Curve 8530 Keypad Replacement: 步骤 4 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement: 步骤 4 中的图像 2,2
    • Flip the phone over so the keyboard faces up.
    • Insert a plastic spudger into the screen where speaker resides.
    • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
    • Gently lift up plastic screen cover until screen cover separates from screen.
    • Continue until screen cover is completely removed.
    询问修复机器人
    添加评论
  5. BlackBerry Curve 8530 Keypad Replacement: 步骤 5 中的图像 1,3 BlackBerry Curve 8530 Keypad Replacement: 步骤 5 中的图像 2,3 BlackBerry Curve 8530 Keypad Replacement: 步骤 5 中的图像 3,3
    • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
    • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
    询问修复机器人
    添加评论
  6. BlackBerry Curve 8530 Keypad Replacement: 步骤 6 中的图像 1,2 BlackBerry Curve 8530 Keypad Replacement: 步骤 6 中的图像 2,2
    • The keyboard should slide off of the phone now that the plastic siding has been removed.
    询问修复机器人
    添加评论
结论
To reassemble the device, follow the instructions in reverse order.
取消:我没有完成这个指南。
4等其他人完成本指南。
Cory Davis
于04/19/11注册
503 声望
创作了3篇指南
团队
Cal Poly, Team 15-13, Regan Spring 2011 Cal Poly, Team 15-13, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G13
3 名成员
创作了11篇指南
1指南评论
This is a handy technique I will use it when next time I fix my phone and if you get time do visit us we fix these type of problems in India, Kolkata here is our site link https://techyuga.com/kolkata/
Ankita - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 29
总计 6,823
