简介
If your phone is not responding to a known good memory card there might be a problem with the socket. This repair may seem difficult, but the component itself is very easy to remove once exposed.
你所需要的
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Use plastic opening tool to pry away tiny metal arm that is holding the socket in place.
Lift SD memory card socket away from phone housing till it is removed.
另外一个人完成了本指南。
