跳转到主内容
加入维修社区 - 创建账户
BlackBerry 7100g Battery Terminal Replacement
你所需要的
    1. BlackBerry 7100g Battery Terminal Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn over your BalckBerry 7100g so that the back cover is facing up.
      • Locate the battery cover release button near the bottom of the back panel.
      询问修复机器人
      添加评论
    2. BlackBerry 7100g Battery Terminal Replacement: 步骤 2 中的图像 1,3 BlackBerry 7100g Battery Terminal Replacement: 步骤 2 中的图像 2,3 BlackBerry 7100g Battery Terminal Replacement: 步骤 2 中的图像 3,3
      • Push down on the release button with one thumb.
      • Slide the battery cover off with the other thumb.
      询问修复机器人
      添加评论
    3. BlackBerry 7100g Battery Terminal Replacement: 步骤 3 中的图像 1,1
      • Remove the battery from the battery housing by flipping up the top of the battery.
      询问修复机器人
      添加评论
    1. BlackBerry 7100g Battery Terminal Replacement, Housing: 步骤 4 中的图像 1,3 BlackBerry 7100g Battery Terminal Replacement, Housing: 步骤 4 中的图像 2,3 BlackBerry 7100g Battery Terminal Replacement, Housing: 步骤 4 中的图像 3,3
      • Locate the silver strip near the top of your BlackBerry.
      • Use a plastic opening tool to pry off the edge of the silver lining.
      • Slide the tool along the length of the silver strip to completely remove it.
      询问修复机器人
      添加评论
    2. BlackBerry 7100g Battery Terminal Replacement: 步骤 5 中的图像 1,2 BlackBerry 7100g Battery Terminal Replacement: 步骤 5 中的图像 2,2
      • Do not lose the screws. They are quite small and can easily be misplaced.
      • Locate and unscrew the four (4) screws using a T6 screwdriver.
      询问修复机器人
      添加评论
    3. BlackBerry 7100g Battery Terminal Replacement: 步骤 6 中的图像 1,3 BlackBerry 7100g Battery Terminal Replacement: 步骤 6 中的图像 2,3 BlackBerry 7100g Battery Terminal Replacement: 步骤 6 中的图像 3,3
      • The keypad cover may fall out of the housing when prying the housing apart.
      • Tightly pinch the top of the front and back halves of the housing.
      • Carefully pry the two halves of the housing apart.
      询问修复机器人
      添加评论
    4. BlackBerry 7100g Battery Terminal Replacement: 步骤 7 中的图像 1,1
      • You can now easily remove the "guts" of the phone from the housing.
      询问修复机器人
      添加评论
    1. BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: 步骤 8 中的图像 1,2 BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: 步骤 8 中的图像 2,2
      • Remove the four screws holding the battery and speaker housing to the motherboard.
      询问修复机器人
      添加评论
    2. BlackBerry 7100g Battery Terminal Replacement: 步骤 9 中的图像 1,3 BlackBerry 7100g Battery Terminal Replacement: 步骤 9 中的图像 2,3 BlackBerry 7100g Battery Terminal Replacement: 步骤 9 中的图像 3,3
      • Once the battery housing is seperated from the motherboard, the battery terminal will slide off the battery housing.
      • The small plastic piece with four metal pins is the battery terminal shown in the third picture.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Kellan
于03/30/10注册
277 声望
创作了3篇指南
团队
Cal Poly, Team 25-87, Amido Spring 2010 Cal Poly, Team 25-87, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G87
4 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 32
总计 3,556
