跳转到主内容
加入维修社区 - 创建账户
Beats Studio First Generation Headband Replacement
你所需要的
    1. Beats Studio First Generation Headband Replacement, Removing the outer headband screws.: 步骤 1 中的图像 1,1
      • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
      • 4 (2 per side) Torx type T5, 3.5mm long screws.
      添加评论
    2. Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 步骤 2 中的图像 1,2 Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 步骤 2 中的图像 2,2
      • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
      添加评论
    3. Beats Studio First Generation Headband Replacement, Removing the hinge pins.: 步骤 3 中的图像 1,1
      • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
      • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
      添加评论
    4. Beats Studio First Generation Headband Replacement, Removing the metal bands.: 步骤 4 中的图像 1,1
      • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
      • 4 (2 per side) Torx type T5, 4.0mm long screws.
      添加评论
    5. Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 步骤 5 中的图像 1,3 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 步骤 5 中的图像 2,3 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 步骤 5 中的图像 3,3
      • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
      添加评论
    6. Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 步骤 6 中的图像 1,2 Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 步骤 6 中的图像 2,2
      • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
      • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
      • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
      添加评论
结论
取消:我没有完成这个指南。
20等其他人完成本指南。
Anand Mangal
于04/15/14注册
1,101 声望
创作了2篇指南
团队
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G18
4 名成员
创作了42篇指南
2指南评论
where can i buy the pin for the hinge i woud like you know email the link to this email drkimaging@gmail.com
derek - 回复 分享
When replacing the headband there is no need to remove any screws or hinges for the beats studio 1.0 as described here.
Simply carefully remove the headband cushion by snapping it out from the frame as it is merely a push fir and not reattained at the two ends it is just push fit into the top plastic section. Just tease it out gently with small screwdriver and then the the replacement in place and listen to the click as it snaps in. Simple and easy takes less than a minute.
Roger Holland - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 116
总计 82,858
