跳转到主内容
Beats Studio 2 Wireless Speaker Replacement
你所需要的
  1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: 步骤 1 中的图像 2,2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Speaker Replacement: 步骤 2 中的图像 1,3 Beats Studio 2 Wireless Speaker Replacement: 步骤 2 中的图像 2,3 Beats Studio 2 Wireless Speaker Replacement: 步骤 2 中的图像 3,3
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Beats Studio 2 Wireless Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Speaker Replacement: 步骤 4 中的图像 1,1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Speaker Replacement: 步骤 5 中的图像 1,2 Beats Studio 2 Wireless Speaker Replacement: 步骤 5 中的图像 2,2
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Speaker Replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
结论
After soldering the new speaker, reassemble your device by following the steps in reverse order.
2等其他人完成本指南。
Mike Rosiello
于03/20/23注册
301 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 25
总计 161
