跳转到主内容
加入维修社区 - 创建账户
Beats Studio 2 Wireless Bluetooth Board Replacement
你所需要的
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: 步骤 1 中的图像 2,2
      • Insert a spudger between the plastic part of the left headphone and the ear cushion.
      • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
      询问修复机器人
      添加评论
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 2 中的图像 1,3 Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 2 中的图像 2,3 Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 2 中的图像 3,3
      • Pull the rest of the cushion away from the adhesive with your hands.
      询问修复机器人
      添加评论
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: 步骤 3 中的图像 1,2 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: 步骤 3 中的图像 2,2
      • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
      • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
      询问修复机器人
      添加评论
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 4 中的图像 1,1
      • Gently separate the speaker from the headphones.
      • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
      询问修复机器人
      添加评论
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 5 中的图像 1,2 Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 5 中的图像 2,2
      • Gently pull the wire with rubber connectors off of the speaker.
      询问修复机器人
      添加评论
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 6 中的图像 1,1
      • Use a soldering iron to desolder the two connections.
      • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
      • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
      • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
      询问修复机器人
      添加评论
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: 步骤 7 中的图像 1,1
      • Peel off the sticker underneath the speaker.
      询问修复机器人
      添加评论
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 8 中的图像 1,1
      • Remove the center screw using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 9 中的图像 1,1
      • Separate the plastic case from the rubber backing by hand or with a spudger.
      询问修复机器人
      添加评论
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 10 中的图像 1,2 Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 10 中的图像 2,2
      • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
      询问修复机器人
      添加评论
    5. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 11 中的图像 1,1
      • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
      • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
      询问修复机器人
      添加评论
    6. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 12 中的图像 1,1
      • Slide the front case down to separate it from the back and reveal the Bluetooth board.
      询问修复机器人
      添加评论
    7. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 13 中的图像 1,2 Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 13 中的图像 2,2
      • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
      • This will free the Bluetooth board from the back case.
      询问修复机器人
      添加评论
    8. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 14 中的图像 1,2 Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 14 中的图像 2,2
      • Remove the Bluetooth board from the case.
      • Remove the translucent sticker from the back of the Bluetooth board.
      询问修复机器人
      添加评论
    9. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 15 中的图像 1,1
      • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
      询问修复机器人
      添加评论
    10. Beats Studio 2 Wireless Bluetooth Board Replacement: 步骤 16 中的图像 1,1
      • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
      • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
      • The soldering iron can reach very high temperatures. Use it with caution.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Jack Wilson
于03/20/23注册
599 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G3
3 名成员
创作了16篇指南
1指南评论
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 56
总计 2,946
