Follow this guide to replace a damaged battery terminal.
Inside the terminal there are small plastic teeth that lock the metal pin to the plastic part of the terminal.
Use a small screwdriver or blade to bend these teeth out of the way.
All need to be bent out of the way in order to remove the plastic part of the terminal.
Use a screwdriver to wedge out the plastic part of the terminal.
Push the metal post back towards batter while removing the plastic part.
There is some glue in behind, but no other fixings so it will come out.
Line up the flat sides of the new terminal with the flat side on the metal post
Place the plastic terminal over the metal post, and use some small needle nose plier to pull the post over the teeth so that they engage
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
