跳转到主内容
Battery Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnection, Heat the rear glass: 步骤 1 中的图像 1,1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 1,3 Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 2,3 Battery Disconnection, Insert an opening pick: 步骤 2 中的图像 3,3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Battery Disconnection, Slice the adhesive: 步骤 3 中的图像 1,2 Battery Disconnection, Slice the adhesive: 步骤 3 中的图像 2,2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Battery Disconnection, Slice the adhesive: 步骤 4 中的图像 1,3 Battery Disconnection, Slice the adhesive: 步骤 4 中的图像 2,3 Battery Disconnection, Slice the adhesive: 步骤 4 中的图像 3,3
    • When you slice near the glyph, insert only the tip of the opening pick (~2-3 mm) to avoid damaging the LEDs.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Battery Disconnection: 步骤 5 中的图像 1,2 Battery Disconnection: 步骤 5 中的图像 2,2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Battery Disconnection: 步骤 6 中的图像 1,2 Battery Disconnection: 步骤 6 中的图像 2,2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
  7. Battery Disconnection, Remove the rear glass: 步骤 7 中的图像 1,2 Battery Disconnection, Remove the rear glass: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    Dust Blower
    $5.99
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Since the rear glass of the Nothing Phone (1) is transparent a dust blower may come in handy for cleaning before installing a new rear glass.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Battery Disconnection, Remove the plastic cover: 步骤 8 中的图像 1,3 Battery Disconnection, Remove the plastic cover: 步骤 8 中的图像 2,3 Battery Disconnection, Remove the plastic cover: 步骤 8 中的图像 3,3
    • The plastic covering the earpiece speaker is held in place by mild adhesive. If you're having a hard time removing it, apply a heated iOpener for 1-2 minutes to loosen the adhesive underneath.
    • Insert an opening pick underneath the grey plastic cover at the top edge of your phone.
    • Use your opening pick to pry up the plastic cover.
    • Remove the plastic cover.
  9. Battery Disconnection, Unfasten the earpiece speaker screws: 步骤 9 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the earpiece speaker.
  10. Battery Disconnection, Remove the earpiece speaker: 步骤 10 中的图像 1,3 Battery Disconnection, Remove the earpiece speaker: 步骤 10 中的图像 2,3 Battery Disconnection, Remove the earpiece speaker: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
    • Use your spudger to pry up the earpiece speaker.
    • Use a pair of tweezers or your fingers to remove the earpiece speaker.
  11. Battery Disconnection, Disconnect the flash assembly LED glyph cables: 步骤 11 中的图像 1,3 Battery Disconnection, Disconnect the flash assembly LED glyph cables: 步骤 11 中的图像 2,3 Battery Disconnection, Disconnect the flash assembly LED glyph cables: 步骤 11 中的图像 3,3
    • Use a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
    • Use a spudger to disconnect the LED glyph cable by prying the connector straight up from its socket.
  12. Battery Disconnection, Remove the recording indicator light cover: 步骤 12 中的图像 1,3 Battery Disconnection, Remove the recording indicator light cover: 步骤 12 中的图像 2,3 Battery Disconnection, Remove the recording indicator light cover: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • Insert an opening pick underneath the recording indicator light cover at the top right corner of the screen.
    • Use a pair of tweezers or your fingers to remove the recording indicator light cover.
  13. Battery Disconnection, Remove the bottom LED glyph assembly: 步骤 13 中的图像 1,3 Battery Disconnection, Remove the bottom LED glyph assembly: 步骤 13 中的图像 2,3 Battery Disconnection, Remove the bottom LED glyph assembly: 步骤 13 中的图像 3,3
    • Be very careful when working on the bottom LED assembly. There's a cable running underneath its whole surface that can be damaged easily.
    • The bottom LED assembly is held in place by small pieces of adhesive.
    • Slide an opening pick underneath the right, bottom and left edge of the bottom LED assembly to carefully separate it from the daughterboard cover.
    • Do not slide the opening pick deeper than shown in the photos. Otherwise you risk damaging the LED cable.
  14. Battery Disconnection, Fold over the bottom LED assembly: 步骤 14 中的图像 1,2 Battery Disconnection, Fold over the bottom LED assembly: 步骤 14 中的图像 2,2
    • The bottom LED assembly is still held in place by a small piece of adhesive sitting between the cable winds. Avoid straining or tearing the cable when folding the assembly over.
    • Use a pair of blunt nosed tweezers and carefully fold the bottom LED assembly over to get free access to the LED cable connector.
  15. Battery Disconnection, Open the connector bracket: 步骤 15 中的图像 1,3 Battery Disconnection, Open the connector bracket: 步骤 15 中的图像 2,3 Battery Disconnection, Open the connector bracket: 步骤 15 中的图像 3,3
    • The LED connector bracket sits very tight and may require some force to open it.
    • Insert one arm of a pair of tweezers into the gap at the right side of the connector bracket.
    • Push your tweezers toward the left edge of the phone to free the closure flap of the connector bracket.
    • If you're struggling to free the flap, pull the black rubber piece to the left to give the bracket more room.
    • Lift the connector bracket with your tweezers to access the LED connector.
  16. Battery Disconnection, Disconnect the LED cable: 步骤 16 中的图像 1,2 Battery Disconnection, Disconnect the LED cable: 步骤 16 中的图像 2,2
    • Use a spudger to disconnect the LED cable by prying the connector straight up from its socket.
  17. Battery Disconnection, Remove the bottom LED assembly: 步骤 17 中的图像 1,2 Battery Disconnection, Remove the bottom LED assembly: 步骤 17 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the bottom LED assembly.
  18. Battery Disconnection, Unfasten the daughterboard cover screws: 步骤 18 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the five 4.2 mm-long screws securing the daughterboard cover.
    • The center-most screw is covered by a white sticker.
  19. Battery Disconnection, Remove the plastic shield: 步骤 19 中的图像 1,2 Battery Disconnection, Remove the plastic shield: 步骤 19 中的图像 2,2
    • The grey plastic shield on top of the daughterboard cover is held in place by mild adhesive.
    • Use a pair of tweezers to carefully separate the grey plastic shield from the daughterboard cover and remove it.
  20. Battery Disconnection, Fingerprint cable information: 步骤 20 中的图像 1,1
    • When prying up the daughterboard cover in the following step be very careful and avoid levering with too much force or to press your prying tool too deep underneath the cover. Otherwise, the fingerprint cable running underneath can be easily torn.
  21. Battery Disconnection, Pry up the daughterboard cover: 步骤 21 中的图像 1,2 Battery Disconnection, Pry up the daughterboard cover: 步骤 21 中的图像 2,2
    • Insert the pointed end of a spudger underneath the top edge of the daughterboard cover just above the black rubber guard securing the LED connector bracket.
    • Pry up with the spudger to release the daughterboard cover from its clips.
  22. Battery Disconnection, Remove the daughterboard cover: 步骤 22 中的图像 1,2 Battery Disconnection, Remove the daughterboard cover: 步骤 22 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the daughterboard cover.
  23. Battery Disconnection, Remove the black rubber guard: 步骤 23 中的图像 1,2 Battery Disconnection, Remove the black rubber guard: 步骤 23 中的图像 2,2
    • Use a pair of tweezers to remove the black rubber guard securing the LED connector bracket.
  24. Battery Disconnection, Remove the connector bracket: 步骤 24 中的图像 1,2 Battery Disconnection, Remove the connector bracket: 步骤 24 中的图像 2,2
    • Use a pair of tweezers to remove the LED connector bracket.
  25. Battery Disconnection, Disconnect the interconnect cable: 步骤 25 中的图像 1,2 Battery Disconnection, Disconnect the interconnect cable: 步骤 25 中的图像 2,2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  26. Battery Disconnection, Separate the interconnect cable adhesive: 步骤 26 中的图像 1,3 Battery Disconnection, Separate the interconnect cable adhesive: 步骤 26 中的图像 2,3 Battery Disconnection, Separate the interconnect cable adhesive: 步骤 26 中的图像 3,3
    • The interconnect cable is held in place by mild adhesive.
    • Carefully slide an opening pick underneath the interconnect cable to separate it from the charging coil assembly and the loudspeaker.
  27. Battery Disconnection, Fold over the interconnect cable: 步骤 27 中的图像 1,2 Battery Disconnection, Fold over the interconnect cable: 步骤 27 中的图像 2,2
    • During the following step do not fold the cable sharply and only bend it to avoid cable damage.
    • Use a pair of tweezers to fold the interconnect cable to the left like you'd open the cover of a book.
  28. Battery Disconnection, Unfasten the motherboard cover screws: 步骤 28 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the four 4.2 mm-long screws securing the motherboard cover.
  29. Battery Disconnection, Separate the wireless charging coil adhesive: 步骤 29 中的图像 1,2 Battery Disconnection, Separate the wireless charging coil adhesive: 步骤 29 中的图像 2,2
    • The charging coil assembly is held in place by mild adhesive.
    • Insert an opening pick underneath the bottom right edge of the charging coil assembly.
    • Slide the opening along the right edge of the charging coil assembly to separate the adhesive.
  30. Battery Disconnection: 步骤 30 中的图像 1,2 Battery Disconnection: 步骤 30 中的图像 2,2
    • Insert an opening pick underneath the bottom left edge of the charging coil assembly.
    • Slide the opening along the left edge of the charging coil assembly to separate the adhesive.
  31. Battery Disconnection, Fold over the charging board assembly: 步骤 31 中的图像 1,2 Battery Disconnection, Fold over the charging board assembly: 步骤 31 中的图像 2,2
    • When folding the charging coil assembly over avoid straining components and cables.
    • Carefully fold the charging coil to the top edge of the phone to access the motherboard cover screws.
  32. Battery Disconnection, Unfasten the motherboard cover screws: 步骤 32 中的图像 1,1
    • Use a Phillips screwdriver to remove the three 4.2 mm-long screws securing the motherboard cover.
  33. Battery Disconnection, Separate the camera cover and flash assembly: 步骤 33 中的图像 1,3 Battery Disconnection, Separate the camera cover and flash assembly: 步骤 33 中的图像 2,3 Battery Disconnection, Separate the camera cover and flash assembly: 步骤 33 中的图像 3,3
    • Return the charging coil to its original position.
    • Don't try to remove the camera cover and flash assembly all the way. Its cable runs underneath the motherboard cover and is very fragile.
    • Carefully slide an opening pick underneath the camera cover and flash assembly to separate it from the motherboard cover.
  34. Battery Disconnection, Fold over the camera cover and flash assembly: 步骤 34 中的图像 1,2 Battery Disconnection, Fold over the camera cover and flash assembly: 步骤 34 中的图像 2,2
    • Avoid straining the camera cover and flash assembly cable when folding it over.
    • Use a pair of tweezers to carefully fold the camera cover and flash assembly toward the battery.
  35. Battery Disconnection, Unfasten the motherboard cover screws: 步骤 35 中的图像 1,1
    • Use a Torx T5 screwdriver to remove the two 4.2 mm-long screws securing the motherboard cover.
    • Return the camera cover and flash assembly to its original position.
  36. Battery Disconnection, Pry up the motherboard cover: 步骤 36 中的图像 1,3 Battery Disconnection, Pry up the motherboard cover: 步骤 36 中的图像 2,3 Battery Disconnection, Pry up the motherboard cover: 步骤 36 中的图像 3,3
    • Carefully fold the charging coil to the top edge of the phone to access the bottom edge of the motherboard cover.
    • Insert the flat end of a spudger underneath the bottom right edge of the motherboard cover.
    • Pry up with the spudger to release the motherboard cover from its clips.
    • Repeat the prying procedure for the bottom left edge of the motherboard cover.
  37. Battery Disconnection, Remove the LED glyph assembly: 步骤 37 中的图像 1,3 Battery Disconnection, Remove the LED glyph assembly: 步骤 37 中的图像 2,3 Battery Disconnection, Remove the LED glyph assembly: 步骤 37 中的图像 3,3
    • Remove the LED glyph assembly.
  38. Battery Disconnection, Disconnect the battery cable: 步骤 38 中的图像 1,2 Battery Disconnection, Disconnect the battery cable: 步骤 38 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
结论
Dominik Schnabelrauch
于11/23/16注册
248,242 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,828篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 59
