跳转到主内容
加入维修社区 - 创建账户
Battery Disconnect
你所需要的
    1. Battery Disconnect, SIM Card: 步骤 1 中的图像 1,2 Battery Disconnect, SIM Card: 步骤 1 中的图像 2,2
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      询问修复机器人
      添加评论
    2. Battery Disconnect: 步骤 2 中的图像 1,2 Battery Disconnect: 步骤 2 中的图像 2,2
      • Remove the SIM card tray from the phone.
      • The SIM card(s) and SD card will fall out of the tray easily.
      • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
      • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
      询问修复机器人
      添加评论
    1. Battery Disconnect, Back Cover: 步骤 3 中的图像 1,1
      • The back cover is held in place by plastic clips.
      • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
      询问修复机器人
      添加评论
    2. Battery Disconnect: 步骤 4 中的图像 1,1
      • Slide the opening pick to the bottom left corner to release the clips.
      询问修复机器人
      添加评论
    3. Battery Disconnect: 步骤 5 中的图像 1,1
      • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
      询问修复机器人
      添加评论
    4. Battery Disconnect: 步骤 6 中的图像 1,1
      • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
      询问修复机器人
      添加评论
    5. Battery Disconnect: 步骤 7 中的图像 1,1
      • Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
      询问修复机器人
      添加评论
    6. Battery Disconnect: 步骤 8 中的图像 1,1
      • Remove the back cover.
      询问修复机器人
      添加评论
    1. Battery Disconnect, Motherboard Cover: 步骤 9 中的图像 1,1
      • Remove screws from the motherboard antenna cover.
      • 3 Phillips #00, 3mm length.
      询问修复机器人
      添加评论
    2. Battery Disconnect: 步骤 10 中的图像 1,1
      在这个步骤中使用的工具:
      • Use the tip of a spudger or tweezers to remove the antenna cover.
      询问修复机器人
      添加评论
    3. Battery Disconnect: 步骤 11 中的图像 1,1
      • Remove screws from the motherboard cover.
      添加评论
    4. Battery Disconnect: 步骤 12 中的图像 1,1
      • Use the tip of a spudger or tweezers to remove the motherboard cover.
      询问修复机器人
      添加评论
    1. Battery Disconnect, Battery Disconnect: 步骤 13 中的图像 1,2 Battery Disconnect, Battery Disconnect: 步骤 13 中的图像 2,2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      询问修复机器人
      添加评论
    2. Battery Disconnect: 步骤 14 中的图像 1,1
      • Gently flex the battery connector away from its socket.
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Thomas Boland
于09/29/20注册
1,932 声望
创作了5篇指南
2指南评论
Do I need to heat up the screen of my phone to make it easier for me to get the back cover off of my phone?
Pifase - 回复 分享
no, it just clips on, there's no adhesive
Ely Wickander - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 54
总计 3,205
