跳转到主内容
加入维修社区 - 创建账户
Basis Peak Motherboard Replacement
你所需要的
  1. Basis Peak Motherboard Replacement, Frame: 步骤 1 中的图像 1,1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
    询问修复机器人
    添加评论
  2. Basis Peak Motherboard Replacement: 步骤 2 中的图像 1,2 Basis Peak Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
    询问修复机器人
    添加评论
  3. Basis Peak Motherboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
    询问修复机器人
    添加评论
  4. Basis Peak Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
    询问修复机器人
    添加评论
  5. Basis Peak Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the right side ribbon cable by pulling it off with your fingers.
    询问修复机器人
    添加评论
  6. Basis Peak Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the spudger tool to poke out the exposed motherboard section as seen in the photo.
    • As always be careful when disconnecting the cables or batteries.
    询问修复机器人
    添加评论
  7. Basis Peak Motherboard Replacement: 步骤 7 中的图像 1,1
    • Put a nylon spudger underneath the battery's press-fit connector and lift up to free the ribbon cable and motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,214
