跳转到主内容
加入维修社区 - 创建账户
Backpack Base Replacement
你所需要的
    1. Backpack Base Replacement, Base: 步骤 1 中的图像 1,2 Backpack Base Replacement, Base: 步骤 1 中的图像 2,2
      • Turn the backpack inside out.
      询问修复机器人
      添加评论
    2. Backpack Base Replacement: 步骤 2 中的图像 1,1
      • Seam rip the binding along the bottom rectangle of the backpack.
      • Discard the ripped panel of burlap.
      • Make sure to set aside the lining fabric before discarding the burlap.
      询问修复机器人
      添加评论
    3. Backpack Base Replacement: 步骤 3 中的图像 1,3 Backpack Base Replacement: 步骤 3 中的图像 2,3 Backpack Base Replacement: 步骤 3 中的图像 3,3
      • Iron the base panel of the polyester lining fabric.
      • Place the lining fabric on top of the desired fabric.
      • Using a ruler and rotary cutter, cut an identical rectangle.
      • Carefully round the corners of your desired fabric rectangle to match the shape of the liner.
      • Use caution when ironing the base panel.
      询问修复机器人
      添加评论
    4. Backpack Base Replacement: 步骤 4 中的图像 1,3 Backpack Base Replacement: 步骤 4 中的图像 2,3 Backpack Base Replacement: 步骤 4 中的图像 3,3
      • Pin the liner and new fabric panel together, so that the 'right sides' of the fabric are facing outwards.
      • Set your machine to the longest stitch length (usually 5 mm), and the loosest thread tension.
      • Not every machine will allow you to adjust the thread tension. If yours allows you to adjust it, set it to zero.
      • Sew the layers together with a 1/4" seam allowance.
      询问修复机器人
      添加评论
    5. Backpack Base Replacement: 步骤 5 中的图像 1,3 Backpack Base Replacement: 步骤 5 中的图像 2,3 Backpack Base Replacement: 步骤 5 中的图像 3,3
      • Pin the lining and new fabric base so that it is centered on the thick side of the backpack.
      • Using a zipper foot, sew the new fabric base and liner to the thick side of the backpack.
      • Be careful to align the corners of the base to the corners of the backpack.
      询问修复机器人
      添加评论
    6. Backpack Base Replacement: 步骤 6 中的图像 1,3 Backpack Base Replacement: 步骤 6 中的图像 2,3 Backpack Base Replacement: 步骤 6 中的图像 3,3
      • Make note of how much larger the fabric base is in comparison to the remaining 3 sides of the backpack.
      • Using a contrasting-colored thread, hand-sew along the corners of the base fabric.
      • Tighten the contrasting threads to bunch up the corners until they fit snug into the corners of the backpack.
      • Pin the remaining 3 sides of the base with to the 3 sides of the backpack.
      询问修复机器人
      添加评论
    7. Backpack Base Replacement: 步骤 7 中的图像 1,3 Backpack Base Replacement: 步骤 7 中的图像 2,3 Backpack Base Replacement: 步骤 7 中的图像 3,3
      • Sew along the remaining three sides.
      • Be extra careful around the corners to avoid any hard creases or folds.
      • Seam-rip the contrasting color thread.
      • Trim down any fabric that exceeds 1/4" seam allowance, particularly around the corners.
      询问修复机器人
      添加评论
    8. Backpack Base Replacement: 步骤 8 中的图像 1,2 Backpack Base Replacement: 步骤 8 中的图像 2,2
      • Turn the backpack right side out.
      • Look along the new seam for any of the stitches that hold the lining and base fabric together, and remove them.
      • Pin the binding around the bottom seam, so that it sandwiches the seam allowance.
      • Allow one end of the binding to remain loose.
      询问修复机器人
      添加评论
    9. Backpack Base Replacement: 步骤 9 中的图像 1,3 Backpack Base Replacement: 步骤 9 中的图像 2,3 Backpack Base Replacement: 步骤 9 中的图像 3,3
      • Starting with the pinned end of the binding, carefully sew about 1/10" away from the end of the binding.
      • When you reach the loose end of the binding, connect the end that you already sewed with the loose end.
      • Sew both ends together.
      询问修复机器人
      添加评论
    10. Backpack Base Replacement: 步骤 10 中的图像 1,3 Backpack Base Replacement: 步骤 10 中的图像 2,3 Backpack Base Replacement: 步骤 10 中的图像 3,3
      • Check the inside and out for any flaws or hard creases.
      • Enjoy your newly repaired backpack!
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
Sheen Patel
于02/21/23注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 63
总计 2,297
