跳转到主内容
加入维修社区 - 创建账户
Back Case
你所需要的
    1. Back Case, Battery: 步骤 1 中的图像 1,1
      • Orient camera to look directly at battery compartment side as shown.
      询问修复机器人
      添加评论
    2. Back Case: 步骤 2 中的图像 1,3 Back Case: 步骤 2 中的图像 2,3 Back Case: 步骤 2 中的图像 3,3
      • Locate the two latches on the battery compartment.
      • First, move the "lock" switch left to reveal red indicator.
      • Next, move the "cover latch" switch downward to reveal red indicator.
      • You have to move the switches in that order for the compartment to unlatch.
      询问修复机器人
      添加评论
    3. Back Case: 步骤 3 中的图像 1,2 Back Case: 步骤 3 中的图像 2,2
      • Allow the battery compartment latch to completely open.
      • Insert battery with the writing face up.
      • The bigger slot is for the battery. The smaller slot is for the memory card.
      • Battery not shown.
      询问修复机器人
      添加评论
    1. Back Case, Back Case: 步骤 4 中的图像 1,1
      • Orient the camera so you are looking at the bottom.
      • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
      询问修复机器人
      添加评论
    2. Back Case: 步骤 5 中的图像 1,1
      • Orient the camera so you are looking at the side plate.
      • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
      询问修复机器人
      添加评论
    3. Back Case: 步骤 6 中的图像 1,2 Back Case: 步骤 6 中的图像 2,2
      • Orient the camera so you are looking at the front plate.
      • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
      • Remove the "Olympus" plate.
      添加评论
    4. Back Case: 步骤 7 中的图像 1,1
      • Remove face plate.
      询问修复机器人
      添加评论
    5. Back Case: 步骤 8 中的图像 1,3 Back Case: 步骤 8 中的图像 2,3 Back Case: 步骤 8 中的图像 3,3
      • Locate three small black screws inside of the battery compartment.
      • Remove the 3.85mm Phillips #00 screw on the far left side.
      • Remove the two 5mm Phillips #00 screws on the right side
      询问修复机器人
      添加评论
    6. Back Case: 步骤 9 中的图像 1,3 Back Case: 步骤 9 中的图像 2,3 Back Case: 步骤 9 中的图像 3,3
      • Orient the camera to be look at the top.
      • Remove the 5.4mm Phillips #00 screw on the top left side.
      • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
      • Pry off top button plate with black nylon spudger.
      询问修复机器人
      添加评论
    7. Back Case: 步骤 10 中的图像 1,2 Back Case: 步骤 10 中的图像 2,2
      • Rotate to bottom of camera and locate bottom latch.
      • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
      • Push firmly apart.
      • Some buttons might fall out.
      询问修复机器人
      添加评论
    8. Back Case: 步骤 11 中的图像 1,3 Back Case: 步骤 11 中的图像 2,3 Back Case: 步骤 11 中的图像 3,3
      • Orient the camera to the LCD screen side that is now wedged open.
      • Locate the white ribbon cable and pull out from motherboard.
      • Locate the brown ribbon cable and pull out from motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G2
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 1,159
