跳转到主内容
加入维修社区 - 创建账户
BOSE SoundTouch 30 Motherboard Replacement
你所需要的
    1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: 步骤 1 中的图像 1,2 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: 步骤 1 中的图像 2,2
      • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
      询问修复机器人
      添加评论
    1. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: 步骤 2 中的图像 1,1
      • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
      询问修复机器人
      添加评论
    2. BOSE SoundTouch 30 Motherboard Replacement: 步骤 3 中的图像 1,2 BOSE SoundTouch 30 Motherboard Replacement: 步骤 3 中的图像 2,2
      • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
      • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
      添加评论
    3. BOSE SoundTouch 30 Motherboard Replacement: 步骤 4 中的图像 1,1
      • Remove all four 15.5 mm PH2 screws holding the power supply down.
      • The power supply is identified by a green board with a large metal covering.
      添加评论
    4. BOSE SoundTouch 30 Motherboard Replacement: 步骤 5 中的图像 1,2 BOSE SoundTouch 30 Motherboard Replacement: 步骤 5 中的图像 2,2
      • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
      • Pick up the power supply and remove the fourth cable from the underside of the power supply.
      • Remove the power supply.
      添加评论
    1. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
      • Remove the five 15.5 mm PH2 screws holding the motherboard down.
      • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
      • Remove the motherboard.
      • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Brennen Irey
于04/18/18注册
1,269 声望
创作了6篇指南
团队
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G2
4 名成员
创作了14篇指南
5指南评论
Where do I can get the power supply?
Ulises Peña - 回复 分享
where can i get the notherboard? 354437-0060
guillermo gibson - 回复 分享
Please where can I get the motherboard
Marjorie Newell - 回复 分享
Where can I get the motherboard?
Bryan Lozano - 回复 分享
I am getting an error “Error code 0000. Contact Bose service” what do I do?
Ashley Murray - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 72
总计 7,672
