跳转到主内容
加入维修社区 - 创建账户
BLU Advance 4.0 Screen Replacement
你所需要的
  1. BLU Advance 4.0 Screen Replacement, Removing the back cover: 步骤 1 中的图像 1,2 BLU Advance 4.0 Screen Replacement, Removing the back cover: 步骤 1 中的图像 2,2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
    添加评论
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 步骤 2 中的图像 1,3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 步骤 2 中的图像 2,3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: 步骤 2 中的图像 3,3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
    询问修复机器人
    添加评论
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: 步骤 3 中的图像 1,1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
    询问修复机器人
    添加评论
  4. BLU Advance 4.0 Screen Replacement, Screen: 步骤 4 中的图像 1,2 BLU Advance 4.0 Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
    询问修复机器人
    添加评论
  5. BLU Advance 4.0 Screen Replacement: 步骤 5 中的图像 1,2 BLU Advance 4.0 Screen Replacement: 步骤 5 中的图像 2,2
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
    询问修复机器人
    添加评论
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: 步骤 6 中的图像 1,1
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Jon Sclar
于11/13/14注册
292 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G2
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 57
总计 4,372
