跳转到主内容
加入维修社区 - 创建账户
B. Front Panel
你所需要的
  1. B. Front Panel, Front Panel Assembly: 步骤 1 中的图像 1,2 B. Front Panel, Front Panel Assembly: 步骤 1 中的图像 2,2
    • Start by placing the NeoPixel rings into the circles. Make sure the pins are at the top center.
    • Thread the Inner Fan part into the circle.
    • Thread the tip into the Inner Fan.
    询问修复机器人
    添加评论
  2. B. Front Panel, Front Panel Assembly: 步骤 2 中的图像 1,2 B. Front Panel, Front Panel Assembly: 步骤 2 中的图像 2,2
    • Screw the assembled Circle parts into the Front Face using 12x M3x8 countersunk screws
    询问修复机器人
    添加评论
  3. B. Front Panel, Front Panel Assembly: 步骤 3 中的图像 1,3 B. Front Panel, Front Panel Assembly: 步骤 3 中的图像 2,3 B. Front Panel, Front Panel Assembly: 步骤 3 中的图像 3,3
    • Glue the letters into the Middle Name Plate
    • Slide in the Middle Name Plate, Left and Right Nets into the Assembled Front Panel
    • Using 2x M3x8 button head screws secure the Middle Name Plate to the Assembled Front Panel.
    询问修复机器人
    添加评论
  4. B. Front Panel, Front Panel Assembly: 步骤 4 中的图像 1,1
    • Slide in the Left and Right Grill into the Front Panel Assembly
    询问修复机器人
    添加评论
  5. B. Front Panel, Front Panel Mounting: 步骤 5 中的图像 1,2 B. Front Panel, Front Panel Mounting: 步骤 5 中的图像 2,2
    • The Front Panel mounts to the Frame with 4x M3x8 socket head/button head screws with 4x M3 T-Nuts and 2x M5x10 button head screws with 2 M5 T-Nuts
    • The Left and Right Lower Front Grill mount to the frame of the printer with 4x M3x8 button head screws with 4x M3 T-Nuts
    询问修复机器人
    添加评论
  6. B. Front Panel, LCD: 步骤 6 中的图像 1,3 B. Front Panel, LCD: 步骤 6 中的图像 2,3 B. Front Panel, LCD: 步骤 6 中的图像 3,3
    • Mount the backplate to the arm with 2x M3x8 button head screws.
    • Mount the ball to the arm with 1x M3x8 socket head screw.
    • I also used a drop of superglue.
    • Insert the PanelDue into the backplate lining up the screw holes. Screw the backplate to the front plate with 4x M3x10 button head screws.
    • Mount the full assembly to the front frame re-enforcement with 2x M5x10 button head screws and 2x M5 T-nuts
    询问修复机器人
    添加评论
  7. B. Front Panel, Results: 步骤 7 中的图像 1,2 B. Front Panel, Results: 步骤 7 中的图像 2,2
    • Looks pretty cool huh?
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
4等其他人完成本指南。
David Husolo
于06/16/21注册
9,382 声望
创作了33篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 22
总计 1,667
