跳转到主内容
加入维修社区 - 创建账户
Axess SPBT1031 Battery Replacement
你所需要的
  1. Axess SPBT1031 Battery Replacement, Red Interface Plate: 步骤 1 中的图像 1,1
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
    询问修复机器人
    添加评论
  2. Axess SPBT1031 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  3. Axess SPBT1031 Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
    询问修复机器人
    添加评论
  4. Axess SPBT1031 Battery Replacement: 步骤 4 中的图像 1,1
    • Separate the red interface plate from the black face plate by pulling them apart.
    询问修复机器人
    添加评论
  5. Axess SPBT1031 Battery Replacement, Black Faceplate: 步骤 5 中的图像 1,1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
    询问修复机器人
    添加评论
  6. Axess SPBT1031 Battery Replacement: 步骤 6 中的图像 1,1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
    询问修复机器人
    添加评论
  7. Axess SPBT1031 Battery Replacement, Battery: 步骤 7 中的图像 1,1
    • Look into the back of the black face plate and find the battery which is wrapped in green.
    • Battery is glued in place, remove by peeling it off.
    添加评论
  8. Axess SPBT1031 Battery Replacement: 步骤 8 中的图像 1,1
    • Once the glue is removed, look into the red interface plate and then locate the bottom of the motherboard.
    • On the bottom of the motherboard, locate the black and red wire connected to the plastic red socket and remove the white insert from this socket.
    添加评论
  9. Axess SPBT1031 Battery Replacement: 步骤 9 中的图像 1,1
    • Run the black and red wire in reverse through the hole in the black face plate to remove the battery.
    • Remove the battery from the black face plate.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G6
3 名成员
创作了8篇指南
3指南评论
ok, so is there any reason that I would not be able to put in a bigger battery for longer play? I realize I would have to mount it differently.
bartman777 - 回复 分享
why it is easily connect this blue tooth to cellphone done connecting to computer. Well not connect any of my 3 laptop computer ??????????????
htosee3791 - 回复 分享
What battery is used for the speaker?
De'Eric Dortch - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 67
总计 9,376
