跳转到主内容
加入维修社区 - 创建账户
AvertX HD810 IR LED Lightboard Replacement
你所需要的
    1. AvertX HD810 IR LED Lightboard Replacement, Clear Dome Cover: 步骤 1 中的图像 1,3 AvertX HD810 IR LED Lightboard Replacement, Clear Dome Cover: 步骤 1 中的图像 2,3 AvertX HD810 IR LED Lightboard Replacement, Clear Dome Cover: 步骤 1 中的图像 3,3
      • Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
      • Optimally, the device should be turned off and the PoE (Power over Ethernet) unplugged.
      询问修复机器人
      添加评论
    2. AvertX HD810 IR LED Lightboard Replacement: 步骤 2 中的图像 1,2 AvertX HD810 IR LED Lightboard Replacement: 步骤 2 中的图像 2,2
      • Loosen both 10mm screws on either side of the clear dome cover housing using a T10 Torx security screwdriver.
      • It is not recommended to remove the screws from the clear dome cover housing. The screws are apart of the cover and not intended to come out.
      询问修复机器人
      添加评论
    3. AvertX HD810 IR LED Lightboard Replacement: 步骤 3 中的图像 1,3 AvertX HD810 IR LED Lightboard Replacement: 步骤 3 中的图像 2,3 AvertX HD810 IR LED Lightboard Replacement: 步骤 3 中的图像 3,3
      • Gently pull off the clear dome cover from the camera base.
      询问修复机器人
      添加评论
    1. AvertX HD810 IR LED Lightboard Replacement, IR LED Lightboard: 步骤 4 中的图像 1,3 AvertX HD810 IR LED Lightboard Replacement, IR LED Lightboard: 步骤 4 中的图像 2,3 AvertX HD810 IR LED Lightboard Replacement, IR LED Lightboard: 步骤 4 中的图像 3,3
      • Use the PH1 screwdriver to remove or loosen both 10mm screws on either side of the inner protective lens cover. This will loosen both the cover and the IR LED lightboard.
      • The cover and the lightboard are two separate pieces held in place by these two screws. The cover should be set aside first before continuing with the lightboard.
      询问修复机器人
      添加评论
    2. AvertX HD810 IR LED Lightboard Replacement: 步骤 5 中的图像 1,3 AvertX HD810 IR LED Lightboard Replacement: 步骤 5 中的图像 2,3 AvertX HD810 IR LED Lightboard Replacement: 步骤 5 中的图像 3,3
      • Pull the IR LED light board gently away from the camera to expose the connecting cable.
      • Firmly but gently detach the IR lED light board from its cable connector by pulling directly away from the connection port.
      • A spudger may be used to loosen a stubborn cable connection. Wedge the flat end of the spudger between the connector and the port to ease it off of the port's prongs.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Hi Luke, do you know of a source for parts (IR LED Board, Motherboard etc…) for this AvertX HD810 camera ? Thanks for the great writeup, Toy
Toy Camry - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 721
