跳转到主内容
加入维修社区 - 创建账户
Automatic Tommy 20 Trigger Spring Replacement
你所需要的
    1. Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: 步骤 1 中的图像 1,2 Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: 步骤 1 中的图像 2,2
      • Locate the orange slider on the front side of the gun.
      • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
      询问修复机器人
      添加评论
    2. Automatic Tommy 20 Trigger Spring Replacement: 步骤 2 中的图像 1,3 Automatic Tommy 20 Trigger Spring Replacement: 步骤 2 中的图像 2,3 Automatic Tommy 20 Trigger Spring Replacement: 步骤 2 中的图像 3,3
      • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
      • Remove all parts within the chamber to be able to completely detach the nose of the gun.
      • Be careful to keep track of all the components for reassembly.
      询问修复机器人
      添加评论
    1. Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: 步骤 3 中的图像 1,3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: 步骤 3 中的图像 2,3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: 步骤 3 中的图像 3,3
      • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
      • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
      询问修复机器人
      添加评论
    2. Automatic Tommy 20 Trigger Spring Replacement: 步骤 4 中的图像 1,1
      • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
      询问修复机器人
      添加评论
    1. Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: 步骤 5 中的图像 1,2 Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: 步骤 5 中的图像 2,2
      • Grab both sides of the gun and pull forcefully in an upward and outward motion to remove from the light green stock.
      • If this is your first time disassembling your gun, the stock will be glued to each half of the gun's body. To break off the stock from the frame of the gun, you will need to careful wiggle the two halves so that the glue will break apart. The plastic on the gun may break or warp slightly.
      询问修复机器人
      添加评论
    2. Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: 步骤 6 中的图像 1,2 Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: 步骤 6 中的图像 2,2
      • Remove the two 1/16 in. screws attaching the battery box to the frame of the gun using a Phillips #00 Screwdriver.
      • Lift the battery box off the frame of the gun to give yourself access to the trigger mechanism.
      询问修复机器人
      添加评论
    3. Automatic Tommy 20 Trigger Spring Replacement, Removing the Screws from the Trigger Mechanism: 步骤 7 中的图像 1,1
      • Remove the two 1/6 in. screws connecting the trigger and trigger spring to the frame of the gun using a Phillips #00 Screwdriver.
      询问修复机器人
      添加评论
    4. Automatic Tommy 20 Trigger Spring Replacement: 步骤 8 中的图像 1,2 Automatic Tommy 20 Trigger Spring Replacement: 步骤 8 中的图像 2,2
      • Lift the plastic trigger away from the gun along with the attached spring.
      • Make sure you do not lift the trigger without the spring or the spring may stretch and no longer function properly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Moira Foster
于10/09/14注册
419 声望
创作了3篇指南
团队
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G22
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 50
总计 1,295
