跳转到主内容
加入维修社区 - 创建账户
August Smart Lock Speaker Replacement
你所需要的
    1. August Smart Lock Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 August Smart Lock Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 August Smart Lock Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
      • Flip the device so the back cover is facing you.
      • Undo the latches on both sides to remove the metal cover.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
      询问修复机器人
      添加评论
    2. August Smart Lock Speaker Replacement: 步骤 2 中的图像 1,3 August Smart Lock Speaker Replacement: 步骤 2 中的图像 2,3 August Smart Lock Speaker Replacement: 步骤 2 中的图像 3,3
      • Use the metal spudger to pry the plug off of the motherboard.
      • The plug can be dislodged when prying it from the side.
      询问修复机器人
      添加评论
    3. August Smart Lock Speaker Replacement: 步骤 3 中的图像 1,3 August Smart Lock Speaker Replacement: 步骤 3 中的图像 2,3 August Smart Lock Speaker Replacement: 步骤 3 中的图像 3,3
      • Warm up the iOpener.
      • Do not place the iOpener in microwave for more than 30 seconds.
      • Place the iOpener heating pad over the speaker and let sit for a few moments.
      • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
      询问修复机器人
      添加评论
    4. August Smart Lock Speaker Replacement: 步骤 4 中的图像 1,2 August Smart Lock Speaker Replacement: 步骤 4 中的图像 2,2
      • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
William Fink
于09/26/17注册
841 声望
创作了3篇指南
团队
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G6
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 27
总计 1,903
