跳转到主内容
加入维修社区 - 创建账户
August Smart Lock Gear Replacement
你所需要的
    1. August Smart Lock Gear Replacement, Gear: 步骤 1 中的图像 1,3 August Smart Lock Gear Replacement, Gear: 步骤 1 中的图像 2,3 August Smart Lock Gear Replacement, Gear: 步骤 1 中的图像 3,3
      • Flip the device over so the metal plate is facing you.
      • Undo the latches on the side to remove the metal plate.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
      添加评论
    2. August Smart Lock Gear Replacement: 步骤 2 中的图像 1,3 August Smart Lock Gear Replacement: 步骤 2 中的图像 2,3 August Smart Lock Gear Replacement: 步骤 2 中的图像 3,3
      • Lift the cover off the device and set to the side.
      • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
      • Remove the gears as shown.
      添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
William Fink
于09/26/17注册
841 声望
创作了3篇指南
团队
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G6
4 名成员
创作了9篇指南
8指南评论
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - 回复 分享
Any tips on where to get replacement gears?
Byron H - 回复 分享
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - 回复 分享
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - 回复 分享
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 66
总计 14,091
