跳转到主内容
加入维修社区 - 创建账户
August Smart Lock Accelerometer Replacement
你所需要的
    1. August Smart Lock Accelerometer Replacement, Accelerometer: 步骤 1 中的图像 1,3 August Smart Lock Accelerometer Replacement, Accelerometer: 步骤 1 中的图像 2,3 August Smart Lock Accelerometer Replacement, Accelerometer: 步骤 1 中的图像 3,3
      • Flip device over so the black bottom is facing you.
      • Undo latches on both sides to remove the metal cover.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
      询问修复机器人
      添加评论
    2. August Smart Lock Accelerometer Replacement: 步骤 2 中的图像 1,3 August Smart Lock Accelerometer Replacement: 步骤 2 中的图像 2,3 August Smart Lock Accelerometer Replacement: 步骤 2 中的图像 3,3
      • Grab the gears and lift them up to remove from the device
      询问修复机器人
      添加评论
    3. August Smart Lock Accelerometer Replacement: 步骤 3 中的图像 1,3 August Smart Lock Accelerometer Replacement: 步骤 3 中的图像 2,3 August Smart Lock Accelerometer Replacement: 步骤 3 中的图像 3,3
      • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
      • Disconnect the speaker plug from the motherboard
      • Disconnect the battery plugs from the motherboard.
      询问修复机器人
      添加评论
    4. August Smart Lock Accelerometer Replacement: 步骤 4 中的图像 1,1
      • Once the speaker is disconnected, remove the back cover.
      • Lift up the motherboard and motor assembly out of the device.
      询问修复机器人
      添加评论
    5. August Smart Lock Accelerometer Replacement: 步骤 5 中的图像 1,2 August Smart Lock Accelerometer Replacement: 步骤 5 中的图像 2,2
      • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
      • Lift up the black tab to remove the ribbon from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
William Fink
于09/26/17注册
841 声望
创作了3篇指南
团队
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G6
4 名成员
创作了9篇指南
7指南评论
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - 回复 分享
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - 回复 分享
Same as above…. where to locate an accelerometer??
osallabe - 回复 分享
Did anyone find out where to buy the part?
LBurd - 回复 分享
Where can I find one
Jeff Wasilewski - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 62
总计 8,904
