跳转到主内容
加入维修社区 - 创建账户
Audiovox Tri-mode CDM-9000 Keypad Replacement
你所需要的
    1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: 步骤 1 中的图像 1,3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: 步骤 1 中的图像 2,3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: 步骤 1 中的图像 3,3
      • Flip your phone over so the screen is facing down.
      • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
      询问修复机器人
      添加评论
    2. Audiovox Tri-mode CDM-9000 Keypad Replacement: 步骤 2 中的图像 1,3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 步骤 2 中的图像 2,3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 步骤 2 中的图像 3,3
      • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
      • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
      询问修复机器人
      添加评论
    3. Audiovox Tri-mode CDM-9000 Keypad Replacement: 步骤 3 中的图像 1,3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 步骤 3 中的图像 2,3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 步骤 3 中的图像 3,3
      • Once you have the phone apart simply remove the key pad and replace it with the new one.
      • Don't forget to put the screws back in. Place the battery back on the phone.
      • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Summer Sines
于09/27/14注册
406 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 25
总计 545
