跳转到主内容
加入维修社区 - 创建账户
Audiovox CDM-8910 Keyboard Replacement
你所需要的
  1. Audiovox CDM-8910 Keyboard Replacement, Antenna: 步骤 1 中的图像 1,1
    • Locate the antenna (shown in red box) at the top of the phone when closed.
    询问修复机器人
    添加评论
  2. Audiovox CDM-8910 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
    询问修复机器人
    添加评论
  3. Audiovox CDM-8910 Keyboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
    询问修复机器人
    添加评论
  4. Audiovox CDM-8910 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
    询问修复机器人
    添加评论
  5. Audiovox CDM-8910 Keyboard Replacement: 步骤 5 中的图像 1,1
    • The back of the phone will look like this when the battery is correctly removed.
    询问修复机器人
    添加评论
  6. Audiovox CDM-8910 Keyboard Replacement, Rear Case: 步骤 6 中的图像 1,1
    • Peel the rubber indicated toward the top of the phone
    询问修复机器人
    添加评论
  7. Audiovox CDM-8910 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove the screw that sits underneath the rubber covering.
    询问修复机器人
    添加评论
  8. Audiovox CDM-8910 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Remove the five (5) total screws using a Philips head screwdriver.
    询问修复机器人
    添加评论
  9. Audiovox CDM-8910 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
    询问修复机器人
    添加评论
  10. Audiovox CDM-8910 Keyboard Replacement: 步骤 10 中的图像 1,1
    • The back case should now be completely removed and the motherboard will be visible.
    询问修复机器人
    添加评论
  11. Audiovox CDM-8910 Keyboard Replacement, Motherboard: 步骤 11 中的图像 1,3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: 步骤 11 中的图像 2,3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
    询问修复机器人
    添加评论
  12. Audiovox CDM-8910 Keyboard Replacement: 步骤 12 中的图像 1,1
    • Using a spudger, lift the motherboard out of the phone case as pictured.
    询问修复机器人
    添加评论
  13. Audiovox CDM-8910 Keyboard Replacement: 步骤 13 中的图像 1,1
    • The motherboard should now be completely removed from the phone.
    询问修复机器人
    添加评论
  14. Audiovox CDM-8910 Keyboard Replacement, Keyboard: 步骤 14 中的图像 1,1
    • Once the motherboard has been removed, peel the keyboard as pictured.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G24
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 1,782
