跳转到主内容
加入维修社区 - 创建账户
Atari 5200 Controller Side Buttons Replacement
你所需要的
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: 步骤 1 中的图像 1,3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: 步骤 1 中的图像 2,3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: 步骤 1 中的图像 3,3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    询问修复机器人
    添加评论
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: 步骤 2 中的图像 1,2 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: 步骤 2 中的图像 2,2
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
    询问修复机器人
    添加评论
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: 步骤 3 中的图像 1,2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: 步骤 3 中的图像 2,2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
    询问修复机器人
    添加评论
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: 步骤 4 中的图像 1,2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: 步骤 4 中的图像 2,2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
    询问修复机器人
    添加评论
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: 步骤 5 中的图像 1,3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: 步骤 5 中的图像 2,3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: 步骤 5 中的图像 3,3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alan Abelson
于09/26/14注册
233 声望
创作了5篇指南
团队
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G1
5 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 30
总计 1,448
