跳转到主内容
加入维修社区 - 创建账户
Atari 5200 Controller Flex Board Replacement
你所需要的
  1. Atari 5200 Controller Flex Board Replacement, Opening up the controller: 步骤 1 中的图像 1,3 Atari 5200 Controller Flex Board Replacement, Opening up the controller: 步骤 1 中的图像 2,3 Atari 5200 Controller Flex Board Replacement, Opening up the controller: 步骤 1 中的图像 3,3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
    询问修复机器人
    添加评论
  2. Atari 5200 Controller Flex Board Replacement, Removing the Circuit Board: 步骤 2 中的图像 1,3 Atari 5200 Controller Flex Board Replacement, Removing the Circuit Board: 步骤 2 中的图像 2,3 Atari 5200 Controller Flex Board Replacement, Removing the Circuit Board: 步骤 2 中的图像 3,3
    • Slide out the strip of the board connected to the controller's START, PAUSE, and RESET buttons.
    询问修复机器人
    添加评论
  3. Atari 5200 Controller Flex Board Replacement: 步骤 3 中的图像 1,3 Atari 5200 Controller Flex Board Replacement: 步骤 3 中的图像 2,3 Atari 5200 Controller Flex Board Replacement: 步骤 3 中的图像 3,3
    • Peel off the old circuit board.
    • The buttons should fall out/be removable.
    • Disconnect it from the wire connector.
    询问修复机器人
    添加评论
  4. Atari 5200 Controller Flex Board Replacement, Adding the new board: 步骤 4 中的图像 1,3 Atari 5200 Controller Flex Board Replacement, Adding the new board: 步骤 4 中的图像 2,3 Atari 5200 Controller Flex Board Replacement, Adding the new board: 步骤 4 中的图像 3,3
    • Place the new circuit board where the old one was.
    • Glue/tape it in places where the previous board was held.
    • Connect it to the wire connector.
    询问修复机器人
    添加评论
  5. Atari 5200 Controller Flex Board Replacement, Reassembly Part 1: 步骤 5 中的图像 1,2 Atari 5200 Controller Flex Board Replacement, Reassembly Part 1: 步骤 5 中的图像 2,2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
    询问修复机器人
    添加评论
  6. Atari 5200 Controller Flex Board Replacement, Reassembly Part 2: 步骤 6 中的图像 1,2 Atari 5200 Controller Flex Board Replacement, Reassembly Part 2: 步骤 6 中的图像 2,2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
    询问修复机器人
    添加评论
  7. Atari 5200 Controller Flex Board Replacement: 步骤 7 中的图像 1,3 Atari 5200 Controller Flex Board Replacement: 步骤 7 中的图像 2,3 Atari 5200 Controller Flex Board Replacement: 步骤 7 中的图像 3,3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the Screws
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 的会员
USFT-STAGGERS-F14S13G1
5 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 36
总计 3,881
