跳转到主内容
加入维修社区 - 创建账户
Asus ZenFone 5 Touch Sensor Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
    1. Asus ZenFone 5 Touch Sensor Replacement, Battery: 步骤 1 中的图像 1,1
      • Heat up the iOpener in the microwave for 30 seconds.
      • Caution: when the iOpener is heated up, hold it by the sides to prevent bodily harm.
      添加评论
    2. Asus ZenFone 5 Touch Sensor Replacement: 步骤 2 中的图像 1,1
      • Place the iOpener on the side of the phone until the iOpener gets cool (approximately 10-15 minutes).
      • Reheat the iOpener and reapply it to the other side of the phone.
      询问修复机器人
      添加评论
    3. Asus ZenFone 5 Touch Sensor Replacement: 步骤 3 中的图像 1,2 Asus ZenFone 5 Touch Sensor Replacement: 步骤 3 中的图像 2,2
      • Gently slide the jimmy along the edges of the phone to break the adhesive.
      • Use opening picks and the opening tool to pry the back cover off.
      • The use of metal tools as shown in the photos is potentially dangerous as the battery is exposed along the edges of the case and risk of puncture is high. Choose an ESD safe tool instead.
      • There are 6 different tabs on each side of the phone that might take force to get apart.
      • Repeat the heating and prying process until the back cover can be fully removed.
      添加评论
    4. Asus ZenFone 5 Touch Sensor Replacement: 步骤 4 中的图像 1,2 Asus ZenFone 5 Touch Sensor Replacement: 步骤 4 中的图像 2,2
      • Use the #00 phillips head to take out the six phillips #00 3.175mm screws on the top cover plate.
      • Use the spudger to release the clasps along the edge of the top plate.
      添加评论
    5. Asus ZenFone 5 Touch Sensor Replacement: 步骤 5 中的图像 1,1
      • Disconnect the press fit connector located near the upper right corner of the battery to disengage the battery from the motherboard.
      添加评论
    6. Asus ZenFone 5 Touch Sensor Replacement: 步骤 6 中的图像 1,2 Asus ZenFone 5 Touch Sensor Replacement: 步骤 6 中的图像 2,2
      • Use the same screwdriver to remove the five phillips #00 3.96mm screws along the bottom plate.
      • Use the spudger to pry the bottom plate off.
      询问修复机器人
      添加评论
    7. Asus ZenFone 5 Touch Sensor Replacement: 步骤 7 中的图像 1,2 Asus ZenFone 5 Touch Sensor Replacement: 步骤 7 中的图像 2,2
      • Pull on the two black tabs on the bottom of the battery until the battery is released.
      • Gently pull the battery out of its socket.
      询问修复机器人
      添加评论
    1. Asus ZenFone 5 Touch Sensor Replacement, Touch Sensor: 步骤 8 中的图像 1,2 Asus ZenFone 5 Touch Sensor Replacement, Touch Sensor: 步骤 8 中的图像 2,2
      • On the back shell of the phone, push with pressure on the touch sensor until it pops out.
      添加评论
结论
取消:我没有完成这个指南。
1指南评论
I might replace the introduction picture in this guide for one that doesn’t have the background missing on the right side.
Alex Watkins - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 21
总计 581
