跳转到主内容
加入维修社区 - 创建账户
Asus X751L Keyboard Replacement
你所需要的
    1. Asus X751L Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
      • With the screen closed, place your laptop upside-down with the front facing you.
      • Remove the six 14.6mm Phillips #00 screws.
      • Remove the four 6.6mm Phillips #00 screws.
      询问修复机器人
      添加评论
    2. Asus X751L Keyboard Replacement: 步骤 2 中的图像 1,1
      • Flip the laptop over and open the lid.
      • Pry around the edges of the laptop base using the plastic opening tool.
      • Prying too hard can break the plastic clips.
      询问修复机器人
      添加评论
    3. Asus X751L Keyboard Replacement: 步骤 3 中的图像 1,3 Asus X751L Keyboard Replacement: 步骤 3 中的图像 2,3 Asus X751L Keyboard Replacement: 步骤 3 中的图像 3,3
      • Carefully lift the keyboard up.
      • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
      • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 17-2, Blackwell Spring 2017 USF Tampa, Team 17-2, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S17G2
4 名成员
创作了35篇指南
1指南评论
Looks easy enough, I have a Polish version qwertz keyboard , a 752L model-17" anyone know a compatible UK qwerty keyboard as a replacement? - or or a k. board shared with another model that will fit ? Asus service centre are less than helpful .!
phil.kath4 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 3,756
