跳转到主内容
加入维修社区 - 创建账户
Asus X551CA Power Button Replacement
你所需要的
  1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: 步骤 1 中的图像 1,1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    添加评论
  2. Asus X551CA Power Button Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    询问修复机器人
    添加评论
  3. Asus X551CA Power Button Replacement: 步骤 3 中的图像 1,1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    询问修复机器人
    添加评论
  4. Asus X551CA Power Button Replacement: 步骤 4 中的图像 1,3 Asus X551CA Power Button Replacement: 步骤 4 中的图像 2,3 Asus X551CA Power Button Replacement: 步骤 4 中的图像 3,3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    添加评论
  5. Asus X551CA Power Button Replacement: 步骤 5 中的图像 1,1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    添加评论
  6. Asus X551CA Power Button Replacement, Power Button: 步骤 6 中的图像 1,1
    • Locate the power button in the corner of the keyboard plate cover.
    • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
    询问修复机器人
    添加评论
  7. Asus X551CA Power Button Replacement: 步骤 7 中的图像 1,1
    • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
    询问修复机器人
    添加评论
  8. Asus X551CA Power Button Replacement: 步骤 8 中的图像 1,1
    • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
Josh
于04/10/14注册
2,970 声望
创作了12篇指南
团队
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G22
5 名成员
创作了15篇指南
1指南评论
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 13,349
