跳转到主内容
加入维修社区 - 创建账户
Asus X551CA Fan Replacement
你所需要的
  1. Asus X551CA Fan Replacement, Keyboard Plate Cover: 步骤 1 中的图像 1,1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    添加评论
  2. Asus X551CA Fan Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    询问修复机器人
    添加评论
  3. Asus X551CA Fan Replacement: 步骤 3 中的图像 1,1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    询问修复机器人
    添加评论
  4. Asus X551CA Fan Replacement: 步骤 4 中的图像 1,3 Asus X551CA Fan Replacement: 步骤 4 中的图像 2,3 Asus X551CA Fan Replacement: 步骤 4 中的图像 3,3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    添加评论
  5. Asus X551CA Fan Replacement: 步骤 5 中的图像 1,1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    添加评论
  6. Asus X551CA Fan Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    添加评论
  7. Asus X551CA Fan Replacement: 步骤 7 中的图像 1,1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    询问修复机器人
    添加评论
  8. Asus X551CA Fan Replacement: 步骤 8 中的图像 1,1
    • Once it is free, remove the hard drive from its internal cavity.
    询问修复机器人
    添加评论
  9. Asus X551CA Fan Replacement, Spacer: 步骤 9 中的图像 1,1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    添加评论
  10. Asus X551CA Fan Replacement: 步骤 10 中的图像 1,1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    询问修复机器人
    添加评论
  11. Asus X551CA Fan Replacement, WiFi Card: 步骤 11 中的图像 1,1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    询问修复机器人
    添加评论
  12. Asus X551CA Fan Replacement: 步骤 12 中的图像 1,1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    询问修复机器人
    添加评论
  13. Asus X551CA Fan Replacement: 步骤 13 中的图像 1,1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    添加评论
  14. Asus X551CA Fan Replacement, Battery: 步骤 14 中的图像 1,1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    添加评论
  15. Asus X551CA Fan Replacement, Motherboard: 步骤 15 中的图像 1,1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    添加评论
  16. Asus X551CA Fan Replacement: 步骤 16 中的图像 1,2 Asus X551CA Fan Replacement: 步骤 16 中的图像 2,2
    • Now, locate the two wires connected to the motherboard.
    询问修复机器人
    添加评论
  17. Asus X551CA Fan Replacement: 步骤 17 中的图像 1,2 Asus X551CA Fan Replacement: 步骤 17 中的图像 2,2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
    添加评论
  18. Asus X551CA Fan Replacement: 步骤 18 中的图像 1,2 Asus X551CA Fan Replacement: 步骤 18 中的图像 2,2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
    添加评论
  19. Asus X551CA Fan Replacement: 步骤 19 中的图像 1,1
    • Remove the motherboard from the case by gently lifting it upward.
    询问修复机器人
    添加评论
  20. Asus X551CA Fan Replacement, Fan: 步骤 20 中的图像 1,1
    • Once the mother board is removed, locate the fan.
    询问修复机器人
    添加评论
  21. Asus X551CA Fan Replacement: 步骤 21 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
    询问修复机器人
    添加评论
  22. Asus X551CA Fan Replacement: 步骤 22 中的图像 1,1
    • Lift the fan out of the laptop.
    添加评论
结论
取消:我没有完成这个指南。
8等其他人完成本指南。
Josh
于04/10/14注册
2,970 声望
创作了12篇指南
团队
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G22
5 名成员
创作了15篇指南
1指南评论
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 6,197
