跳转到主内容
加入维修社区 - 创建账户
Asus X501A-RH31 Keyboard Replacement
你所需要的
    1. Asus X501A-RH31 Keyboard  Replacement, Battery: 步骤 1 中的图像 1,1
      • Turn the laptop over so that the back is facing upwards.
      询问修复机器人
      添加评论
    2. Asus X501A-RH31 Keyboard  Replacement: 步骤 2 中的图像 1,1
      • To unlock the left tab, make sure the tab on the left has red showing.
      询问修复机器人
      添加评论
    3. Asus X501A-RH31 Keyboard  Replacement: 步骤 3 中的图像 1,2 Asus X501A-RH31 Keyboard  Replacement: 步骤 3 中的图像 2,2
      • To unlock the right tab, push the right slider to the left with one hand.
      • Push the battery out with the other hand.
      询问修复机器人
      添加评论
    1. Asus X501A-RH31 Keyboard  Replacement, Keyboard: 步骤 4 中的图像 1,2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: 步骤 4 中的图像 2,2
      • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
      • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
      询问修复机器人
      添加评论
    2. Asus X501A-RH31 Keyboard  Replacement: 步骤 5 中的图像 1,1
      • Turn the laptop over and open the top so the keyboard is facing you.
      询问修复机器人
      添加评论
    3. Asus X501A-RH31 Keyboard  Replacement: 步骤 6 中的图像 1,2 Asus X501A-RH31 Keyboard  Replacement: 步骤 6 中的图像 2,2
      • Pry off the keyboard cover on the edge using the plastic opening tool.
      • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
      • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
      询问修复机器人
      添加评论
    4. Asus X501A-RH31 Keyboard  Replacement: 步骤 7 中的图像 1,1
      • Slowly lift the keyboard upward, but do not remove completely.
      • Remove the two data cables that attach the keyboard to the motherboard.
      询问修复机器人
      添加评论
    5. Asus X501A-RH31 Keyboard  Replacement: 步骤 8 中的图像 1,1
      在这个步骤中使用的工具:
      • Use tweezers to pull the white plastic piece up that is attached to the data cable.
      • Repeat this process for the big black cable as well.
      • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Romana Hruby
于10/20/17注册
596 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 UMass Dartmouth, Team S3-G3, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G3
3 名成员
创作了56篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,561
