跳转到主内容
加入维修社区 - 创建账户
Asus UL80J Screen Replacement
你所需要的
    1. Asus UL80J Screen Replacement, Battery: 步骤 1 中的图像 1,1
      • Place laptop face down with battery facing up.
      询问修复机器人
      添加评论
    2. Asus UL80J Screen Replacement: 步骤 2 中的图像 1,1
      • Slide unlock button to the right.
      询问修复机器人
      添加评论
    3. Asus UL80J Screen Replacement: 步骤 3 中的图像 1,3 Asus UL80J Screen Replacement: 步骤 3 中的图像 2,3 Asus UL80J Screen Replacement: 步骤 3 中的图像 3,3
      • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
      询问修复机器人
      添加评论
    1. Asus UL80J Screen Replacement, Screen: 步骤 4 中的图像 1,3 Asus UL80J Screen Replacement, Screen: 步骤 4 中的图像 2,3 Asus UL80J Screen Replacement, Screen: 步骤 4 中的图像 3,3
      • Flip laptop back over and open it so that the screen faces you. Several rubber cushions hide screws around the bezel (surrounding frame). Remove these first to get to the screws underneath. The two bottom covers are stickers. Then remove all screws holding the bezel in place.
      • There will be four 3 mm screws located on the top and two 5 mm screws located on the bottom of the bezel.
      询问修复机器人
      添加评论
    2. Asus UL80J Screen Replacement: 步骤 5 中的图像 1,2 Asus UL80J Screen Replacement: 步骤 5 中的图像 2,2
      • Next, completely remove the bezel using a plastic opening tool to work your way around while gently prying it from the LCD. If it does not come off with a moderate amount of force check that you did not miss any screws.
      询问修复机器人
      添加评论
    3. Asus UL80J Screen Replacement: 步骤 6 中的图像 1,1
      • Unscrew the four 3 mm screws that hold the mounting brackets for the screen to the backing.
      询问修复机器人
      添加评论
    4. Asus UL80J Screen Replacement: 步骤 7 中的图像 1,1
      • Gently lay the screen on the keyboard and remove the tape over the connection. You can then disconnect the screen.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. It is a good idea to check that the new screen works before reattaching the bezel.
取消:我没有完成这个指南。
Loren Plopper
于02/19/17注册
213 声望
创作了2篇指南
团队
USF Tampa, Team S2-G4, Lacy Spring 2017 USF Tampa, Team S2-G4, Lacy Spring 2017 的会员
USFT-LACY-S17S2G4
3 名成员
创作了49篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 603
