跳转到主内容
加入维修社区 - 创建账户
Asus Transformer T100 Battery Replacement
你所需要的
  1. Asus Transformer T100 Battery Replacement, Rear Cover: 步骤 1 中的图像 1,2 Asus Transformer T100 Battery Replacement, Rear Cover: 步骤 1 中的图像 2,2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
    询问修复机器人
    添加评论
  2. Asus Transformer T100 Battery Replacement: 步骤 2 中的图像 1,2 Asus Transformer T100 Battery Replacement: 步骤 2 中的图像 2,2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    添加评论
  3. Asus Transformer T100 Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
    询问修复机器人
    添加评论
  4. Asus Transformer T100 Battery Replacement: 步骤 4 中的图像 1,2 Asus Transformer T100 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the rear casing.
    询问修复机器人
    添加评论
  5. Asus Transformer T100 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the copper tape carefully.
    询问修复机器人
    添加评论
  6. Asus Transformer T100 Battery Replacement: 步骤 6 中的图像 1,2 Asus Transformer T100 Battery Replacement: 步骤 6 中的图像 2,2
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
    询问修复机器人
    添加评论
  7. Asus Transformer T100 Battery Replacement: 步骤 7 中的图像 1,3 Asus Transformer T100 Battery Replacement: 步骤 7 中的图像 2,3 Asus Transformer T100 Battery Replacement: 步骤 7 中的图像 3,3
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
    添加评论
  8. Asus Transformer T100 Battery Replacement: 步骤 8 中的图像 1,2 Asus Transformer T100 Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
70等其他人完成本指南。
Taylor Pantiga
于04/14/14注册
1,629 声望
创作了6篇指南
团队
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G31
3 名成员
创作了8篇指南
22指南评论
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - 回复 分享
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes - 回复 分享
what is the battery part # for t100 and can you purchase it?
thank you
RJ - 回复 分享
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - 回复 分享
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 40
过去 30 天: 173
总计 133,328
