跳转到主内容
Asus ROG Ally Battery Replacement
你所需要的
  1. Asus ROG Ally Battery Replacement, Prepare your device for disassembly: 步骤 1 中的图像 1,3 Asus ROG Ally Battery Replacement, Prepare your device for disassembly: 步骤 1 中的图像 2,3 Asus ROG Ally Battery Replacement, Prepare your device for disassembly: 步骤 1 中的图像 3,3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Asus ROG Ally Battery Replacement, Unfasten the back cover: 步骤 2 中的图像 1,2 Asus ROG Ally Battery Replacement, Unfasten the back cover: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Asus ROG Ally Battery Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Asus ROG Ally Battery Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Asus ROG Ally Battery Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Asus ROG Ally Battery Replacement, Release the back cover's clips: 步骤 4 中的图像 1,3 Asus ROG Ally Battery Replacement, Release the back cover's clips: 步骤 4 中的图像 2,3 Asus ROG Ally Battery Replacement, Release the back cover's clips: 步骤 4 中的图像 3,3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Asus ROG Ally Battery Replacement, Remove the back cover: 步骤 5 中的图像 1,3 Asus ROG Ally Battery Replacement, Remove the back cover: 步骤 5 中的图像 2,3 Asus ROG Ally Battery Replacement, Remove the back cover: 步骤 5 中的图像 3,3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
  6. Asus ROG Ally Battery Replacement, Remove the plastic cover: 步骤 6 中的图像 1,3 Asus ROG Ally Battery Replacement, Remove the plastic cover: 步骤 6 中的图像 2,3 Asus ROG Ally Battery Replacement, Remove the plastic cover: 步骤 6 中的图像 3,3
    • Use your fingers to peel up and remove the black plastic cover between the fans.
    • Put the cover aside—you'll use it during reassembly.
  7. Asus ROG Ally Battery Replacement, Unlatch the locking bar: 步骤 7 中的图像 1,3 Asus ROG Ally Battery Replacement, Unlatch the locking bar: 步骤 7 中的图像 2,3 Asus ROG Ally Battery Replacement, Unlatch the locking bar: 步骤 7 中的图像 3,3
    • A metal locking bar secures the top edge of the battery connector
    • Use the flat end of a spudger to gently push the locking bar away from the connector to unlatch it.
  8. Asus ROG Ally Battery Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Asus ROG Ally Battery Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Asus ROG Ally Battery Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
    • Make sure the locking bar is not covering the battery connector at all, or you may damage the socket and the locking bar.
    • Insert the flat end of a spudger under the center of the battery connector.
    • Lift the connector straight up and out of its socket to disconnect the battery.
    • During reassembly, use your fingers or the flat end of a spudger to firmly push the connector onto its socket until it clicks into place.
  9. Asus ROG Ally Battery Replacement, Unfasten the battery: 步骤 9 中的图像 1,3 Asus ROG Ally Battery Replacement, Unfasten the battery: 步骤 9 中的图像 2,3 Asus ROG Ally Battery Replacement, Unfasten the battery: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery:
    • Two 9.6 mm‑long screws near the center of the top edge
    • The screw near the left speaker has a warning sticker on it. Pierce through it with your screwdriver or use tweezers to remove it.
    • Two 3.4 mm‑long screws at the left and right edges
  10. Asus ROG Ally Battery Replacement, Remove the battery: 步骤 10 中的图像 1,3 Asus ROG Ally Battery Replacement, Remove the battery: 步骤 10 中的图像 2,3 Asus ROG Ally Battery Replacement, Remove the battery: 步骤 10 中的图像 3,3
    • With one hand, hold the ribbon cable that runs along the top of the battery out of the way.
    • With your free hand, lift the battery straight up and remove it.
  11. Asus ROG Ally Battery Replacement, Remove the battery cable: 步骤 11 中的图像 1,3 Asus ROG Ally Battery Replacement, Remove the battery cable: 步骤 11 中的图像 2,3 Asus ROG Ally Battery Replacement, Remove the battery cable: 步骤 11 中的图像 3,3
    • If your replacement battery doesn't come with a cable installed, follow this step to remove and transfer the old one.
    • With one hand, firmly secure the outer battery cells.
    • With your free hand, use the point of a spudger to push on alternating sides of the battery connector to walk it out of its socket.
    • To install the cable:
    • Gently push the connector partially into its socket.
    • Use a spudger to push in the outer edges of the connector until it slides fully into its socket.
    • Do not push on the cables themselves, as this can easily damage them.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
于09/14/22注册
55,203 声望
创作了408篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 33
过去 7 天: 207
过去 30 天: 839
总计 2,165
