跳转到主内容
加入维修社区 - 创建账户
Asus Q525U CPU Fan Replacement
你所需要的
  1. Asus Q525U CPU Fan Replacement, Back Cover: 步骤 1 中的图像 1,3 Asus Q525U CPU Fan Replacement, Back Cover: 步骤 1 中的图像 2,3 Asus Q525U CPU Fan Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
    询问修复机器人
    添加评论
  2. Asus Q525U CPU Fan Replacement: 步骤 2 中的图像 1,3 Asus Q525U CPU Fan Replacement: 步骤 2 中的图像 2,3 Asus Q525U CPU Fan Replacement: 步骤 2 中的图像 3,3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
    询问修复机器人
    添加评论
  3. Asus Q525U CPU Fan Replacement: 步骤 3 中的图像 1,3 Asus Q525U CPU Fan Replacement: 步骤 3 中的图像 2,3 Asus Q525U CPU Fan Replacement: 步骤 3 中的图像 3,3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
    询问修复机器人
    添加评论
  4. Asus Q525U CPU Fan Replacement, Battery: 步骤 4 中的图像 1,3 Asus Q525U CPU Fan Replacement, Battery: 步骤 4 中的图像 2,3 Asus Q525U CPU Fan Replacement, Battery: 步骤 4 中的图像 3,3
    • The battery of the device is outlined in red.
    • Using a Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery in place.
    询问修复机器人
    添加评论
  5. Asus Q525U CPU Fan Replacement: 步骤 5 中的图像 1,2 Asus Q525U CPU Fan Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Using the Halberd spudger, carefully lift the battery connector up to disconnect it from the motherboard.
    询问修复机器人
    添加评论
  6. Asus Q525U CPU Fan Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the frame to remove.
    询问修复机器人
    添加评论
  7. Asus Q525U CPU Fan Replacement, CPU Fan: 步骤 7 中的图像 1,1
    • The CPU fan of this device is outlined in purple.
    询问修复机器人
    添加评论
  8. Asus Q525U CPU Fan Replacement: 步骤 8 中的图像 1,3 Asus Q525U CPU Fan Replacement: 步骤 8 中的图像 2,3 Asus Q525U CPU Fan Replacement: 步骤 8 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove five screws from the fan and heatsink.
    • Remove one 3 mm Phillips #1 screw on the side of the CPU fan.
    • Remove four 2 mm Phillips #1 screws from the heatsink.
    询问修复机器人
    添加评论
  9. Asus Q525U CPU Fan Replacement: 步骤 9 中的图像 1,2 Asus Q525U CPU Fan Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Use the Halberd spudger to carefully disconnect the bundled slide connector that connects the CPU fan to the motherboard.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    询问修复机器人
    添加评论
  10. Asus Q525U CPU Fan Replacement: 步骤 10 中的图像 1,3 Asus Q525U CPU Fan Replacement: 步骤 10 中的图像 2,3 Asus Q525U CPU Fan Replacement: 步骤 10 中的图像 3,3
    • Carefully remove the thicker black cord from the cord clips surrounding the fan.
    • Remove the fan from the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Clemson, Team 2-5, Hunter Spring 2022 Clemson, Team 2-5, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G5
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 830
