跳转到主内容
加入维修社区 - 创建账户
Asus PadFone S Front Facing Camera Replacement
你所需要的
    1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: 步骤 1 中的图像 1,1
      • Place your thumb in the charging port and pry the back cover off of the phone.
      询问修复机器人
      添加评论
    2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: 步骤 2 中的图像 1,2 Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: 步骤 2 中的图像 2,2
      • Remove all screws using the T5 Torx screwdriver
      • Lift the back panel off the phone.
      询问修复机器人
      添加评论
    3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Asus PadFone S Front Facing Camera Replacement, Remove the Battery: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Disconnect the battery from the logic board using tweezers
      • Using the plastic opening tools, lift the battery up from its slot
      • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
      询问修复机器人
      添加评论
    1. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: 步骤 4 中的图像 1,3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: 步骤 4 中的图像 2,3 Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: 步骤 4 中的图像 3,3
      • Once the Battery has been successfully removed, move on to the step 2.
      询问修复机器人
      添加评论
    2. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: 步骤 5 中的图像 1,2 Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: 步骤 5 中的图像 2,2
      在这个步骤中使用的工具:
      • Disconnect the marked strips from the logic board using the tweezers.
      • Applying too much force may damage the strips/connectors.
      • Remember to remove speaker connection located at the bottom left hand corner.
      询问修复机器人
      添加评论
    3. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: 步骤 6 中的图像 1,2 Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: 步骤 6 中的图像 2,2
      • Disconnect the other two strips that connect the logic board to the phone.
      询问修复机器人
      添加评论
    4. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: 步骤 7 中的图像 1,2 Asus PadFone S Front Facing Camera Replacement, Remove The Camera: 步骤 7 中的图像 2,2
      • Turn over the logic board to locate the front camera.
      • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
      • Applying to much force will damage the connective strip.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G1
3 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 26
总计 1,833
